UglyUr - PhatPhiveHundred - Daily Project
Took a nice trip to rescue a hurt vehicle back in October...
After seeing the post I emailed the owner. The email address looked extremely familiar but didn't know from where.
Once I received a reply from the owner stating the vehicle was available, I noticed (in gmail) that I had previous conversation thread had been in my inbox since 2009. Turns out it's the same person I bought Rubi from... YAY! (soo far soo good)
What I knew is that the vehicle had been sitting (like Rubi was when I purchased her) as he was in the Medical field and used his bicycle and public transport more than the car itself. Said he purchased it already as a stroker. Did not have details on what the parts included were, but
It had my interest as it could have some worthy bits inside.
After discussing some more details about the vehicle I promptly board on a flight to go pick this thing up and drive it back north to my area (North of Boston).
Handed over the funds, grabbed the paperwork and left...
With the time I had on my hands I did some digging around on the interwebs in search for more information on what the exact history on this vehicle was. All I knew was that it was built by Peter Blaser and that the previous owner before the person I purchased it from was from my neck of the woods, New Hampshire. He also showed me some for sale ad that had a vehicle with a similar build.
The last picture with that catch can was the dead giveaway of something I've never seen until this car and that car .
Dug around some more and found the Avant owner and contacted him to get an idea if both cars were indeed put together by Peter.
As it turns out, that Avant also had spent some time with Marc at EFI and had since reverted back to being a 2.2L car. He was also nice enough to forward Peters direct email. So naturally I set out to find out from the source what exactly this thing had internally for hard parts.
Finally got a reply from him and as I would suspect his memory would naturally be hazy after building this thing over a decade ago. He did however mention that:
We did 3 of them
Silver wagon - His own until 2008 then went to Brian Miller
Red wagon - Bob Pastore
Black sedan - Bryan Lockwood
I had a youtube video of a red sedan doing a 12.1s quarter mile. I didn't put that one together, but I did send them some parts, but that was so long ago... I'd guess there are about 8 of them in running condition in the country right now.
When first asked what the combo used for the internals are he replied:
It is a 144mm forged rod.
The pistons are forged aluminum and sit down 2mm from the deck. I didn't like this because I was told how important the quench area was in these engines. However, they seem to work fine.
The compression ratio is 8.5:1.
* 83mm = 2584cc
He then sent me some "notes" from when the run of parts where ordered... Apparently there was a group buy of 5. Three were assemble by him the other 2 were for customers to assemble. Told me each build came out to $4,000 and these were the options Eurospec had at the time:
2682cc 5 cyl stroker motor
**** CRANKSHAFT ****
074 105 101 $ 785.00 *** Forged 95.5mm 5 cylinder 2.5
**** PISTONS ****
EFP 107 2683 5VT $ 950.00 *** 4V 5CYL 220mm 83 95.5 2337 144 20 28 8.5.1 Dished
**** CONNECTING RODS ****
ECR 198 144 CBLW $1995.00 *** Carrillo Light *** 144mm 475gr 20mm 48mm 5/16
ECR 198 144 CB 20 $1795.00 *** Carrillo Race *** 144mm 600gr 20mm 48mm 3/8
ECR 198 144 BLW $ 620.00 *** OE light shot-peened *** 144mm 590gm 20mm 48mm
026 105 401 $ 369.00 *** Standard Rod *** 144mm 690gm 20mm 48mm
http://www.eurospecsport.com
info@eurospecsport.com
I replied:
So using some backwards math an assembled block was:
$4000
-$ 785.00 *** Forged 95.5mm 5 cylinder 2.5
-$ 950.00 EFP 107 2683 5VT *** 4V 5CYL 220mm 83 95.5 2337 144 20 28 8.5.1 Dished
$2265 left over... Unsure if they all had $1995.00 *** Carrillo Light rods, leaving $270 for the tall deck block & assembly parts(bearings ect) or if Carrillo Race it could even be the $369.00 left over *** (which I highly doubt
Standard Rod would leave $1896 for the block and assembly(bearings assembly)
He replied:
I think they are the shot-peened rods. They were completely assembled short blocks. They did not look at all like Audi rods.
And sent pics of when he did the build in his shop.
So it looks as though this vehicle has slightly changed since it's left it's hands... but as it stands these are the known/verified parts as it stands
today 5 months later after my ownership:
SPECS:
1993 UrS4 - Black on Black
S6 Bumpers and Door Trim
BBS RWII - 17x8 - 2 Piece Wheels
2 Bennett Coilovers
245/45/17
EuroSpec Build - Circa 2010 Stroker (2.6L?)
95.5mm Crank
82.5mm JE Pistons 8.5:1
ARP Head Studs (yet to see what else)
Effective 2552cc of displacement
(need to confirm on rods, I don't wanna rip it apart tho)
VEMS Standalone
Devils Own Water/Meth
750cc Injector Dynamics
Bosch 044
FlexFuel Sensor
Stromung 3" Exhaust
034 Short Shift Kit
Stage 3 Southbend with 707PP
General Maintenance has already commenced at "when I have time" basis.
But cosmetically it needs bumpers and a hood.
Mechanically I'm sorting out some weird electrical bugs. I hope the harness hasn't nested a home for rodents since it was sitting for soo long.
I have 14v at the battery and alternator but only 12v at the ECU, so I need to get to the bottom of that as it has some weird symptoms under WOT.
The vehicle came with stacks of maintenance work that was done to it that go back 7 years mostly from Marc at EFI which made me feel better about most of the history.
Apparently over time these builds were known for oil consumption because somehow the pistons used sat 2mm under the deck making the overall piston not tall enough to remain straight in the bore at BDC. So I'll deal with that with a simple piston swap from FRP at some point. Before then I should already know if it has stock rods or not as well and act accordingly.
The Goal?
Capitalize on the already 95.5 stroke and max out the turbo if it indeed has rods that could support a full e85 tune.
Logs show 75% Injector DC as is I currently have it on Pump/Meth 28psi. So I might still have some room to play with ethanol. I've swapped in the proper pump and FlexFuel sensor to eventual have a variable map. I Stroked smaller turbo build with a broad powerband for daily use is what this is gonna be... hence the start of a PhatPhiveHundredWhp Build on this UglyUr.
Welcome...
Re: UglyUr - PhatPhiveHundred - Daily Project
Nice save, looks pretty good from 10ft with that polish on the paint!
That's a helluva find. Looking forward to the rescue and build process.
audifreakjim wrote:Nice save, looks pretty good from 10ft with that polish on the paint!
Thanks...
Fenders, doors and quarters a almost immaculate. If I swap the bumpers and hood with a roof respray it'll be a 9 out of 10.
PRY4SNO wrote:That's a helluva find. Looking forward to the rescue and build process.
Thank you, I promise not to make it too extensive. Trying to keep it simple but effective.
Wow! What a find a true gem!
Will be following this one closely, great job so far.
The cut and polish looks :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
p.s. that is a sweet fuel line! Did it come from a friendly's ice cream cup are you going to start producing them?
morris400
Post by morris400 »
Beautiful!
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
Post by jbrentd »
That's quite a list of upgrades...nice score! Does the name "PhatPhiveHundred" have any relation to how much gave for her? If so, wow.
jbrentd wrote:That's quite a list of upgrades...nice score! Does the name "PhatPhiveHundred" have any relation to how much gave for her? If so, wow.
That would be sweet if I did... but no I paid fair market price as most of the mods were disclosed by the previous owner. Which BTW is who I got Rubi from back in 2011. PhatPhiveHundred is a hypothetical power curve I'd like to achieve on the this car seeing as it already has a 95.5mm crank. Going for a broad powerband on this one for daily activities.
morris400 wrote:Beautiful!
Thanks Boss!
themagellan wrote:Wow! What a find a true gem!
Hey you southerner... what's up with my fuel line? Does it look tasty or what???
