VEMS trigger sensors
I know with megasquirt, I can use hall sensors in place of the VR sensors for the flywheel trigger sensors. Would it be possible to do this with VEMS as well?
Re: VEMS trigger sensors
yes. with some hardware changes on the ecu.
Marc wrote:yes. with some hardware changes on the ecu.
Would it be worth the change though? From what I found with a quick search, it looks like the OEM sensors are $120+ each. The hall sensors I'm looking at cost $22 each, and the adaptors I'm looking at making for them would cost about $40 each.
I can get the oem sensors for around $60 new each if you dont mind them being non color coded anymore.
they rarely fail unless they get hit with something.
so, "no", its not really worth swapping them to hall IMO.
That answers that then. Thanks Mark.
