Zerb
Post by Zerb »
it will be the tube the exhaust gas actually passes through. and i kinda thought it was going to be a bit too snug, but thats nothing a die grinder wont fix. :-D
Longitudinal
Post by Longitudinal »
If your engine and exhaust mounts are rock solid, then a quarter inch or so will be fine. But if the exhaust system moves, you will get a contact buzz, if I may neologize, each time the exhaust hits the body.
Zerb
Post by Zerb »
engine mounts are solid mounts, with the 034 track density mounts on the frame ears in the bay. same with the tranny mounts, mount brackets will be solid...subframe mounts will be solid delrin. aluminum subframe bushings as well.
my idea once it was all said and done was to give the pipe a bit more clearance and perhaps wrap it with some exhaust heat wrap so that there is a barrier between the vibrating pipe and the metal.
speeding-g60
Post by speeding-g60 »
i am going with Jonathan.... 1/4" should be good..... and murdered out especially, you will never even notice the gap.
Zerb
Post by Zerb »
alright, ill have to take the die grinder to it tomorrow. at least the hard parts are done, lol.
speeding-g60
i think my exhaust has a 5" holesaw cut to the fender, and i know the pipe is 4" OD. i just never made a pretty-plate to cover it. and my picky ass dont even notice it.... LOL
Zerb
Post by Zerb »
so, i decided that i didnt like the way that i was going to do my fuel system, i set it all up a few months back, so i re-did it.
first, i decided that i wanted to mount the pumps to a plate using tbolt clamps and mount that plate to the floor, so it was solid and easy to put together and take apart. also, wanted to have the pumps below the sump. so had my buddy make me a plate with two tbolt clamps welded onto it, theyre not welded TO the plate, they have a strap going over them so that they can be adjusted angle wise. had him weld bolts to the plate and then drilled holes to mount it to the floor. add some rubber hose around the outside of the 044 pumps to cut down on vibration a bit and thats that.
-8 to the pumps, -8 out to the Y-block, and -8 all the way up to the rail, ss braided the entire way. i had a piece of solid ss tube to run under the car, but then thats two more fittings that need to be bought and its just as easy to run braided the entire way.
Zerb
Post by Zerb »
so, i got my turbo today....thanks to clay@CTSturbo for the hookup this thing.
specs.
.70 a/r compressor housing
billet compressor wheel
ceramic ball bearing
.82 a/r exhaust housing
three inch v-band outlet
i dont want to say what type of power this will make for me, all i will say is that it will be alot, lol.
death 4kqt
Post by death 4kqt »
good god!
O2VW1.8T
Post by O2VW1.8T »
Thats sick, that turbo should make plenty of HP.
speeding-g60
dry humping turbo.....
Zerb
Post by Zerb »
damn, it does look like im trying to bang that thing.
Toxcheap
Post by Toxcheap »
nut hugging lmao
Frank the quattro tank
Post by Frank the quattro tank »
That milk looks old :wtf: . Nice looking turbo!
Post by glibobbo21 »
why isnt it tapped for a dp, or have a vband?
Justin517
Post by Justin517 »
looks like a v-band to me. :?
Zerb
Post by Zerb »
vband casted into the exhaust housing.
.... that is sexy....
oh i only saw the straight on shot lol..whoops
Zerb
Post by Zerb »
two more, just cause its that tits...
RSCoupe
Post by RSCoupe »
That impeller wheel is :drool: !!
Mark Siggelkow
'90 CQ-R - NASA GTS-4
'12 TT-RS (Wife's DD)
'00 A4 1.8TQ (My DD)
'62 356B (vintage racer)
waxcoupe
Post by waxcoupe »
Holy shit!
:woowoo: :stupid:
Zerb
Post by Zerb »
ok, so painted the bay today, started in the trunk as well. also got alotta stuff powdercoated. head will be here assembled tuesday, then i can put the long block together. paint and assemble. :woowoo:
bay/trunk
powdercoated pile
3 inch vband on the throttle body
side exit exhaust
speeding-g60
your shizzle be running before mine will LOL
