So ive gotten into the Vems wiring and have a few questions:
1. Does anyone know the polarity of the audi crank sensors? I just cut the whole sensor wiring out of my oe mc1 harness so it should be shielded and it looks good. I know the brown is shield ground but not sure of the yellow and black wires as to which needs to go to which pin for the vems.
2. I might need to call efi express who set up the ecu for me, but I wasn't sure which pins to use for the mc1 idle control valve. I do know I need to put a diode across it.
3. I'm guessing I should use a 5v power for the cam sensor hall sourced from pin 36/28?
4. I have an innovate lc1 wide band gauge, any ideas on how to keep the gauge and use just one o2 sensor?
5. I picked up an 034 high output coil set and was wondering if anyone had suggestions on getting some custom plug wires. Summit Jeggs?? I'm hope they are AEM coils because that's how I wired them
