eS2 evolution
Re: eS2 evolution
Post by Afterthought »
Engine bay looks great. I really hated sanding all that on my URQ !
What’s that master cyl??
FFF
Re: eS2 evolution
Post by FFF »
Thanks. Certainly a pain but I wouldn’t have been happy if I hadn’t cleaned it up given how stripped the car is.
It’s a Wildwood from ChaseBay. Found a couple of E30 guys that run them that like the setup.
“They” say that this is the sweet spot for pedal feel and power based on master cylinder piston diameter. I kept the hydro-boost in case I don’t like it...I don’t mind a heavier pedal as long as it is a linear feel.
FFF
Re: eS2 evolution
Post by FFF »
A little more accomplished.
Front end is close to being reinstalled.
KW Variant 3’s
AKMotorsport 12mm offset top mounts.
FFF
Re: eS2 evolution
Post by FFF »
KW Variant 3’s
FFF
Re: eS2 evolution
Post by FFF »
Ok that’s weird, gave me an error on the post and a double post...
Re: eS2 evolution
That's Tapatalk for you lol
Man everything is just going in so smoothly, looks minty fresh. How did you remove the old subframe and control arm bushings?
FFF
Re: eS2 evolution
Post by FFF »
PRY4SNO wrote:That's Tapatalk for you lol
The control arm bushings I just used a air hammer. The front subframe was super easy because I pulled the from out.
1 1/4 hole saw to drill out the center bushing.
Then an air chisel to pop them out. Maybe 15 minutes in total.
FFF
Re: eS2 evolution
Post by FFF »
FFF
Re: eS2 evolution
Post by FFF »
WTF on the double posts. I post, then a notice saying double post. If I cancel, it doesn’t post anything, but if I retry it’s doing it twice?
Re: eS2 evolution
That's a tapatalk fail... one of a few prominent reasons I abandoned the platform (personally speaking).
Good call on the combo of the hole saw and air chisel, I think I see some of that in my future. Thanks for the pointers!
Re: eS2 evolution
Here’s the secret recipe .
Post (will get error message )
Ignore errors . Hit back button
It will ask if you want to abandon post . Say yes.
It takes you back to your thread and no changes appear . Go back to main forum page then go forward to your thread again. Now the new post appears .
That is what has been workin for me at least. Even though it says the post didn’t work it really did so if you post again it will duplicate , or give you the “top soon” message .
FFF
Re: eS2 evolution
Post by FFF »
Perfect, thanks.
the german
Re: eS2 evolution
Post by the german »
This exchange has affirmed my decision never to use Tapatalk
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
FFF
Re: eS2 evolution
Post by FFF »
the german wrote:This exchange has affirmed my decision never to use Tapatalk
Really the main reason I use it is I am too lazy to do photos through a hosting service...
Re: eS2 evolution
Yeah it’s a pain, but for me it’s better than uploading each photo to a hosting site and trying to translate the link.
That is Until Tapatalk deletes the photos stored then every thread looks like all the other ones where photobucket was used
Re: eS2 evolution
Honestly, imgur isn't that convoluted.
FFF
Re: eS2 evolution
Post by FFF »
AKMotorsports front track rods installed.
FFF
Re: eS2 evolution
Post by FFF »
Looking for some input - I have a couple of thoughts on this but wondering if others have found a really good way to clean the carpet while out of the car...
Re: eS2 evolution
Pressure washer with carpet cleaner.
FFF
Re: eS2 evolution
Post by FFF »
Slow progress.
Used Sonix wheel cleaner to clean front calipers. Amazing how well it worked.
Front end back on
Re: eS2 evolution
#sofreshandsoclean
rallyfreak202
Re: eS2 evolution
Post by rallyfreak202 »
Looks awesome. I didn't know AK made those front tie rod ball/heim joint assemblies. Nice! I have a homebrew setup on the rally car. Love the parts and quality this build is getting.
FFF
Re: eS2 evolution
Post by FFF »
rallyfreak202 wrote:Looks awesome. I didn't know AK made those front tie rod ball/heim joint assemblies. Nice! I have a homebrew setup on the rally car. Love the parts and quality this build is getting.
Thanks - I’m hoping to do a little track stuff, 1/2 mile etc (maybe do One Lap of America), play on the streets and am not willing to go at it half assed given the performance I am seeking... have to be able to stop and turn! My main struggle is that I chose to not do a cage... I guess I will see if I change my mind on that later (most likely but...).
FFF
Re: eS2 evolution
Post by FFF »
Finally getting back to some work on the car, I’ve been travelling a ton for work and trying to get some family time so haven’t done a thing...
I wish I had given a little more thought to doing the rear subframe bushings earlier, I should have waited until I dropped it out. I initially was planning on doing the rear end bushings with the frame in the car but figured it will be easier to do everything with the frame out....
I think I’ll seam weld up the sub frame while it is out... for anyone that has done it any concerns with warping if it’s not bolted in car? Way easier on a bench...
Re: eS2 evolution
Bad ass .. you’re not leaving anything untouched
