You know what I say to that.a4kquattro wrote:I'll probably re-use the 3.6 intake manifold and modified breather plate off my current motor. Any reason I cant do this?
Ronald G Wainwright+
studs are in
one of the stud holes on the right bank toward the rear had semi-buggered threads though, I chased them and the stud is in but I'm not hugely happy with how it felt going in. Fingers crossed it holds the torque...
RSCoupe
Now would be the time to put a helicoil or Timesert in. Big PIA later.a4kquattro wrote:one of the stud holes on the right bank toward the rear had semi-buggered threads though, I chased them and the stud is in but I'm not hugely happy with how it felt going in. Fingers crossed it holds the torque...
Better safe than sorry...
HT Motorsport
RSCoupe wrote:Now would be the time to put a helicoil or Timesert in. Big PIA later.a4kquattro wrote:one of the stud holes on the right bank toward the rear had semi-buggered threads though, I chased them and the stud is in but I'm not hugely happy with how it felt going in. Fingers crossed it holds the torque...
:stupid:
odd thing about that... the closest tap I could find was 12x1.5. The thread pitch looks right but the bolt just feels 'loose' for instance running the stud through a die. Certainly not SAE and 10 is way too small. Just my imagination? Can anyone confirm that the holes are M12X1.5 ?
You're right though, I should helicoil.
HT Motorsport
ETKA should say, I would check but I don't have it here.a4kquattro wrote:odd thing about that... the closest tap I could find was 12x1.5. The thread pitch looks right but the bolt just feels 'loose' for instance running the stud through a die. Certainly not SAE and 10 is way too small. Just my imagination? Can anyone confirm that the holes are M12X1.5 ?
WAUG0806
Dear Santa...
http://www.thread-check-tool.com/
Nice stocking stuffer! Many of us could save hours with one of these for sure!
Quattro Krant
Pretty cool toolWAUG0806 wrote:Dear Santa...
Marc, how did it feel coming out? Was it funky or did it come out fine? Basically you are saying that the bolt feels a tiny bit too small for the threaded hole? If you are going to do a helicoil, now is the time.
the easy thing to do is probably just to call ARP, give them the part number and see what they say...
CANONN90QS
according to Tacoma Screw it's a M11. i got one from them. 8 bucks.odd thing about that... the closest tap I could find was 12x1.5. The thread pitch looks right but the bolt just feels 'loose' for instance running the stud through a die. Certainly not SAE and 10 is way too small. Just my imagination? Can anyone confirm that the holes are M12X1.5 ?
Took down the head bolt. took a bit to figure out.
HT Motorsport
WAUG0806
Never mind... this POS does not have M11 thread checker! I'll have my usual lump of coal instead... :x
11mm helicoil installed so all is well there. Went to go fit my headgaskets and realized my sealed victor reinz gasket set has two right headgaskets in the kit :curses:
Sigh.
Sigh.
Jonathan
32vquattro
yes. And I bought an extra left and right separate... So now I have 3 rights and one left...
32vquattro
32vquattro
cuatrokoop
