Alex's V8 90QS : Cutting the cylinders in half
Re: Alex's V8 90QS : VEMS!
if he's smart he wont care. he knows a guy willing to put in a lift probably wants to stay a while.
And added value to the property!
New 3" SS exhaust arrived yesterday thanks to Alloutofdonuts. Have to weld in a couple v-bands and fab up a new y-pipe. Pics to come when I unbox it after moving.
And apparently Hagerty doesn't deem a 95 Audi 90 a collector vehicle :( So I guess it'll stay on my normal car insurance...we'll see if I can get an agreed value on it so I don't get screwed if it were in an accident. No problems with the Porsche or Merc though.
Grundy!
audifreakjim wrote:Grundy!
I'll get a quote, thanks!
the german
holy. balls. This is awesome. Great score!
Check out your slab before you put in a two-post lift- from what I have seen most normal garage floor slabs don't meet the minimum spec. in thickness or strength.
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
- ringbearer
You could make some "feet" out of some 2" or so thick slabs of plate steel. Drill some holes and check the thickness before you do anything.
Awesome property btw!
Yeah, I've got to make some test holes to see how thick it is. Perhaps they made it thicker for an RV...
Well, Grundy was a joke. I mailed them an application for the Audi and Merc (you can't really do any of it online, you have to print/mail in the application and pictures). 4 weeks later I finally get a response...
Declined due to:
1.) Cars not collectible (I could see the Audi as not, that's what Haggerty said; not sure how Jim got them to agree)
2.) Cars not garaged....Are you kidding me? I said they were both in a locked garage, which they are. Maybe because I took the pictures in the driveway they thought they aren't garaged?
3.) Not all househould drivers listed...I live by myself, I don't know where they got that information. I listed myself as the only driver.
4.) Cars not restored...That was never listed as a requirement.
Wish it would've worked out as they were 1/3 the cost of Haggerty (who also won't insure the Audi). Guess I'll keep shopping...
On another note.... I ordered this:
National Auto Tools Triumph C-7000
Like a MaxJax, but with 72" light height and 7000lb capacity.
Declined due to:
Seeing as how you meet or exceed Grundy's qualifications I'd just argue with them or escalate to someone who can actually make a decision.
I'd even argue the collector's status of the B4, considering they imported less of them than the Cq.
Nice lift, that'll be pretty sweet to use!
Yeah, going to try calling them to see what's up.
As far as my landlord goes, when I asked him if I could install a lift his response was "I want one too! Can you get a two for one deal?"
He's coming over next week to help me plan out where to put it in the garage (after I get some stuff cleaned up).
Got a longer bit and a proper hammer drill (not the shitty attachment on my Craftsman cordless). Couldn't tell exactly where it bottom out with a depth gauge, so out came the new borescope! Pad is 5"! Plenty more than the 3.5-4" minimum.
IMG_20140911_205749727_HDR by alxdgr8, on Flickr
IMG_20140911_205749727_HDR by alxdgr8, on Flickr-Alex-
the german
sweet! glad you don't have to do anything to the pad for a lift. Mine was only 2.5-3" so no lift for me... yet.
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Can you snap a pic of the trigger wheel setup? My coupe setup is going to be a whole lot like yours.
I've finally sourced a bunch of things and am set on a direction.
ABH witb ABZ valve covers and coils
ABZ intake (thanks again for the info on the conversion)
Fidanza flywheel with 034 crank bushing adapter.
i believe VEMS will be my best option since I don't have an ABZ cam sensor setup (or the exhaust cams that drive it) or a 60-2 ring on the flywheel to run the A8 ECU I have. Plus why spend $700 on the chip and immobilizer when VEMS will be a bit more but way more versatile and reusable on a later project if this one fails.
Anyway, I'd love to know what the crank trigger setup is and get your thoughts on it.
CURRENT
PAST
PAST
Grillage wrote:Can you snap a pic of the trigger wheel setup? My coupe setup is going to be a whole lot like yours.
It's the 034 crank trigger wheel and holder that mounts to the serpentine pulley. I can't wait to ditch it with a flywheel trigger when I swap in the 01E
I wonder what the best option is then. I've seen rear main seal trigger wheel combos for 5 cylinders but not 8's
CURRENT
PAST
PAST
Grillage wrote:I wonder what the best option is then. I've seen rear main seal trigger wheel combos for 5 cylinders but not 8's
Best is flywheel trigger for the v8,but the crank can be made to work. I had nothing but problems on mine with 034, hope it is better with VEMS.
I DEMAND EXHAUST VIDEOS!!!
AngryTaco wrote:I DEMAND EXHAUST VIDEOS!!!
In due time...
Once I get the lift installed, this will go on much easier:
IMG_20140927_100958780 by alxdgr8, on FlickrGranted, I still need to finish VEMS to meet your request :(
dude....magnaflow......seriously.....
Call up spintech, order 2 single in/out 9000 series, no balance pipe, and then take video!
Lift is here! Now to get planning to make sure to place it in the right spot and ensure it'll fit all of my vehicles.
IMG_20141101_072911813 by alxdgr8, on Flickr
IMG_20141102_230622199 by alxdgr8, on Flickr
IMG_20141102_230622199 by alxdgr8, on Flickr-Alex-
the german
Nice! Which lift did you get?
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german wrote:Nice! Which lift did you get?
Triumph C7000 from National Auto Tool. It's pretty much a maxjax on steroids
the german
is it fairly mobile like the maxjax, just with a higher lift height?
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german wrote:is it fairly mobile like the maxjax, just with a higher lift height?
Yeah, the posts are a little taller and heavier, but the lift cylinder doesn't protrude out the top like the MaxJax. It's rated for 7000lbs and 72" lifting compared to the MaxJax's 6000lbs and 48" lift.
They originally shipped them last year with wheels, but they had to take it off the market for about 6 months due to a lawsuit from Danmar (the MaxJax maker). Earlier this year they put it back up for sale without the wheels. They still have the holes in the columns, so it'll be easy to make some brackets and mount wheels on the posts.
The posts are 7' 11", so it'll fit with 8' ceilings. It's actually only 6" taller than the MaxJax at a full 48" lift since the cylinders come out the top of the posts on it.
It also has a lot more locking positions than the MaxJax, which I think only has 2.
http://www.nationalautotools.com/vehicl ... uct_id=190
They did a group buy earlier this year for $2225 delivered (it's $2599 now).
