Whoever makes those adapter cups should make a version that allows use of a second clip to keep them in the rail...mushasho wrote:I need my car so I had to do something about it today...
In the meantime double ORing & ZipTies
Re: FID 1200cc Injector Resolution by Loxxrider
Re: Rubi Riding on Crack then Placed on the Rack
loxxrider wrote:I may not have been super clear before... I think the hats are addressing the issues you are pointing out directly. Instead of the shallow groove where the o-ring currently sits, there will be a shoulder there... There will also be clip grooves added to the hats.
Again, I'm very sorry about this... rest assured the new hats will solve the problem
I apparently didn't read everything, lol.
I understand, lots of little details can get lost..Justin517 wrote:I apparently didn't read everything, lol.
She currently sits while some things currently get figured out, new parts arrive to lighten up the mood
GM OEM 13577429 FlexFuel Sensor
GM OEM 13352241 Wiring Harness
30FT of Conductive Core PTFE Fuel Hose
Assorted PTFE Compatible Reusable Fittings
I went with Teflon hoses simply for it's sheer superiority to the commonly used cheaper Nitrile variant. It's resistance to deterioration with corrosive fuels and it's overall flow characteristics made the choice easy. I will never have to touch these hoses again and will probably outlive the car. Money well spent IMO with peace of mind knowing that I've decreased the chance of any lean condition caused by a blocked fuel passage caused by an inferior hose.
Now should I spring for the Zeitronix ECA/LCD unit to feed 0-5V to a VEMS input for Ethanol info or should I limit the amount of gauges and just feed VEMS raw frequency from this sensor and create a gauge in VEMS which I could then duplicate on my Android Device for a readout... (not sure if the latter is possible)
Re: Rubi - In the Meantime
Oh man, I'm just jealous you have 93 octane Vpower let alone e85.
Well I fueled up for the first time that very day and was a able to up the boost gradually as it mixed into the system. By the time I had it dialed in I fried injector output #1 causing that injector to stay wide open.... here's a clear indicator...PRY4SNO wrote:Oh man, I'm just jealous you have 93 octane Vpower let alone e85.
Re: Rubi - Lets Try This Again...
yaaaaay!
That fuel is awesome.
Re: Rubi - Better Rail Fitment
Nice and snug!
Tight is good.
UrSobsessed
Nice! How did you fry output #1?
older ecu without the giant capacitor inside that they put on to deal with this issue that happens on rare occasions.UrSobsessed wrote:Nice! How did you fry output #1?
- themagellan
Marc you are a demi god, too funny. OBI Yeah Buddy!!!
After engine tune is finalized with all its little remaining bits, suspension will come next...
Front subframe mounts arrived...
Re: Rubi - Looking Forward
Who are those from?
Rob
Ob, a dude on s2forum just made 550whp on the 5862... Get on it!
No idea what fuel etc, but spool seemed late, 5k+
http://www.s2forum.com/forum/showthread.php?t=61438
I ain't worried bout nutting' cuz made 780wtq yesterday on my first pass... Lol
The guy on the s2forum has his own brew of cams which is what he's testing. My 7a's should spool this up quicker than his more aggressive regrinds. We'll see when I go to Marc for finalization.
Seems like "never" is the appropriate answer... Lolchaloux wrote:What's your eta for this build? Just whenever it's done?
UrSobsessed
Ha! Sounds about right for me too. Still waiting for parts........mushasho wrote:Seems like "never" is the appropriate answer... Lolchaloux wrote:What's your eta for this build? Just whenever it's done?
Re: Rubi - Dyno Comparison
But seriously, this is a base 24-25psi 3rd gear run to give you an idea of where this is in terms of spool. It's an overlay of my MTM 1+ vs PTE5862. As you can see right were torque plateaus on 1+ is where this one shows up to the party.chaloux wrote:Ob, a dude on s2forum just made 550whp on the 5862... Get on it!
4th gear pulls would've given me better spool and peak numbers, but I didn't bother.
Re: Rubi - Baseline Dyno Pulls
They're from Thuppu on the s2forum...roortube wrote:Who are those from?
The "old" spool looks more like 3400 to me, sure there is a small dip after that but it still looks fully spooled to me.mushasho wrote:But seriously, this is a base 24-25psi 3rd gear run to give you an idea of where this is in terms of spool. It's an overlay of my MTM 1+ vs PTE5862. As you can see right were torque plateaus on 1+ is where this one shows up to the party.chaloux wrote:Ob, a dude on s2forum just made 550whp on the 5862... Get on it!
Yup fully spooled on that k24 line 3400, after the dip it plateaus and falls out right when this one goes into it.Justin517 wrote:
