Wobble Bolts 112 to 114.3 - Yay or nay
20VAvant
Post by 20VAvant »
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
Re: Wobble Bolts 112 to 114.3 - Yay or nay
As long as your wheels are hub centric they're great! I will be running some.
I know 1000 people will say "there's nothing wrong with them they work awesome!", but personally, it is a skip for me. Plenty of 5x112 wheels available.
20VAvant
Post by 20VAvant »
EDIGREG wrote:I know 1000 people will say "there's nothing wrong with them they work awesome!", but personally, it is a skip for me. Plenty of 5x112 wheels available.
I don't like the idea, but it is great for convenience...
Kuma
Post by Kuma »
If you were to swap from lugs to studs, you can get 12mmx1.5 studs and cone seat nuts. Instead of the 14x1.5 studs you still get the same effect of wobble bolts, while retaining the 5x112 part of your car if need be.
I run 12x1.5mm studs with wobble nuts and they are awesome ;) The main reason is so I can run Enkei RPF1's. mine are 17x9.5, damn strong, insanely light, under $250 and readily available.
I have a ton of track days on the wobbles and never had an issue. In fact they stay torqued better than standard conical wheel nuts.
20VAvant
Post by 20VAvant »
audifreakjim wrote:I run 12x1.5mm studs with wobble nuts and they are awesome ;) The main reason is so I can run Enkei RPF1's. mine are 17x9.5, damn strong, insanely light, under $250 and readily available.
Thanks for the answer, I'll have to check those out.
Kuma wrote:If you were to swap from lugs to studs, you can get 12mmx1.5 studs and cone seat nuts. Instead of the 14x1.5 studs you still get the same effect of wobble bolts, while retaining the 5x112 part of your car if need be.
I've wanted to convert to studs for a while but while it's easy to drop a grand on coilovers, that 60$ conversion is a killer! ;) Will also consider this! Thanks
Kuma
Post by Kuma »
www.adaptitusa.com
45$ shipped
20VAvant
Post by 20VAvant »
Kuma wrote:http://www.adaptitusa.com
45$ shipped
I forgot everywhere doesn't charge 034 prices....
Thanks!
Oh, and it was 40$ shipped :D
Kuma
Post by Kuma »
ZING!
