EDIGREG wrote:Let's be honest, you were bouncing off the Bilstein's internal bumpstops with every bump when you blew them in 6 months. I saw your old setup and you'd be lucky to have 1.5" of travel
No shocks are going to put up with that for very long.
Both of my sets of blown konis were on stock UrS lowering springs, for what that's worth. No high rate stuff. Many, many reports of C4 cars with the same issue on Konis. They just aren't suited for the weight of this platform, IMO.
Koni's racing line is fantastic...but really, really expensive.
loxxrider wrote:Either one will blow on you in short order unless re-vavled.
That's why i suggested revalved Bilsteins
Yes, that is why I suggest just finding some Konis to re-valve since they will most-likely be much easier to work with than my nightmare of an experience (two different times now) with Bilstein. Anyway, that is pretty sad about them blowing on the regular lowering springs. I agree, they just aren't valved for a heavy car and high rates. Somehow my E34 does just fine with them except that one bad one though.
By the way, its not like I drove the Audi super low all the time! I had it at reasonable levels probably 80% of the time. Also, the way the top hats were, the car wouldn't ever hit the bump stops since they would hit the gland nut before the strut was all the way compressed. As such, all I'd ever get was a big bang every time I bottomed out, and I didn't like that so I kept it raised quite a bit higher most of the time except for pictures and meets, etc. You are right though, at a ride height that I thought looked good, there was about 1.5" of travel. That sucked. Hopefully that will be fixed now with the shorter struts.
The bottom line is, just try to find whatever you can used and have that re-valved. If you can't find some used, then you'll just have to install new ones, deal with them blowing, then get the re-valved later unless you just want to pony up for the racing Konis right off the bat and not spend an astronomical amount more in the long run... unless those blow too lol.
