Issues from the start:
A6 fenders and front bumper
Hideous wheels
Fuel cut from cheap eBay maf
Poorly done timing belt job (discovered just in time)
Poorly performing injectors
Loose clamps on boost hoses
Cracked vac lines
Rust
Worn suspension
So, I probably way overpaid at $2500, but it’s close to the best $2500 I’ve ever spent.
Progress so far:
BBS wheels with tires for $400
Fenders and bumper from Marcel
Tightened every hose clamp and replaced vac lines
RS2 replica injectors and 3 bar FPR
Spark plugs
While working in the garage with a urS4 owner, we heard a rubbing sound start under the timing belt cover. Luckily, we shut the car off in time and just at the right spot to see this.
The cog had been reuses and broke, then that piece cut the belt.
With encouragement from the FB group, I ordered parts and did a complete timing service.
Mounted my B8 roof rack, with some modifications
Sold my significantly modded B8
Installed a boost gauge
The car has had a TAP stage 2 tune since 1998 and makes boost well.
Now daily driving the S6.
To be done soon.
New springs and koni shocks
Resonator install to fix drone
Other suspension parts
Body work and paint
I thought I would miss my A4 but love the S6 a lot already.
In a couple of months I’ll buy a newer dedicated daily so the project can proceed at a calm pace.
