hardened I5 cog gears are back in stock
EFI-X Product development and new product releases
We now carry the Tommis Billet hardened I5 cog gears. You asked for it, so we got em back for you.
http://www.efiexpress.com/catalog/produ ... ucts_id=23
Re: hardened I5 cog gears are back in stock
Dammit! I just missed out on this! My new one has less than 300 miles on it.
:thumbsup:
Hi - Do the OEM gears wear out because of age, or is the failure due to high torque being applied to it? Cool machined piece.
<puts nose in the air> Thank heavens I don't have to lose sleep over these anymore :)
The stock ones are prone to failure because they are sintered which sounds cool but means they are made of powdered metal. They will break because of fatigue or simply from the simple impulse load an impact gun can put on them.
Oh And good work Marc! Can they be had in a wider belt vversion?
PRA4WX
Post by PRA4WX »
Hank wrote:<puts nose in the air> Thank heavens I don't have to lose sleep over these anymore :)
Haha! 07K elitists....
Fundahl
Post by Fundahl »
Are these "0 balanced" when bolted to stock crank pulley? I found out local machine shop can balance my single mass flywheel conversion, but not my crank pulley with my newly installed billet timing belt gear. I really want my damn S6 to be running again!
I have a VEMS just sitting there.... meth kit waiting.... :)
95 S6, 05 FZ1, 91 300ZX, 05 LJ Rubi
I don't think that you need to worry about balancing the small cog gear. Since it's billet it should be very close out of the box, and it's so small that even if it was greatly out of balance you would never notice it.
