Custom front strut housings for UrS4/UrS6 coilovers...
There has been some demand since I built my coilovers, so I am making these modified strut housings available.
The modifications include a lower seat machined from 4130 hardened steel, removal of OE lower spring perches, and lowering of the steering arm to make room for a 5" coil sleeve and restore factory tie rod geometry. I can also clearance the edges of the steering arms and clock the arms inwards if you prefer (only necessary if running tires wider than 255 - NOTE that this may require shortening of tie rod in order to get toe in spec).
The cost is $350 shipped to your door. You must send me a set of CLEAN, BARE strut housings. I am no longer providing a core exchange program. Note that this includes only modified strut housings, no additional coilover parts or POR15 coating as pictured.
I have only performed these modifications on UrS strut housings, however the same procedures could easily be done on housings for other chassis.
Re: Custom front strut housings for UrS4/UrS6 coilovers...
Nice! This is much needed in the community in my opinion :)
amd is the best
Post by amd is the best »
This job is a decent PIA and I think $350 is VERY worth the price. I would have had you do mine if this way available when I did them. T44 uprights are almost identical for anyone wondering.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
I've got a set done by Ed and they look great!
Kuma
Post by Kuma »
how much more or less work would be involved for a CQ front and rear?
same price?
if so i may go ahead and search for some spare struts and such.
Kuma wrote:how much more or less work would be involved for a CQ front and rear?
same price?
Well, it's more work in that, for the UrS, only the fronts need modified. Otherwise it is the same. Shoot me a PM and we can work something out.
This is awesome :) depending on my laziness I might take you up on this!
versacehobo
Post by versacehobo »
Sent you a PM mate, really need to sort something out ASAP as my car is pretty much rendered useless currently :police:
DannyboyUpstate
Post by DannyboyUpstate »
Are you still doing these?
Yes, still doing them. Send me a PM or email if you are interested
DannyboyUpstate
EDIGREG wrote:Yes, still doing them. Send me a PM or email if you are interested
Hey Ed- I sent you an email based on some address you posted on quattroworld about a week ago. Not sure if it's the right address or it went into your spam folder or whatt? For some reason it wont let me PM you here either.
YGM - what do you mean the site won't let you send me a PM though?
DannyboyUpstate
Replied to mail. I don't know why, but it keeps telling me that the user no longer exists? I have successfully PM'd with other people on this site. Strange.
DannyboyUpstate
Danny - your problem is that you are entering a Subject into the username area (Look a little bit down more), I just did the same thing and came back here to post it :P
DannyboyUpstate
Thanks for the tip Mag. I'll check that out next time I try to PM someone.
blackdude716
Post by blackdude716 »
Will you still be offering these over the winter? Im looking to grab a set before Christmas! Also how much of a drop can I achieve with these on a 93 urs4?
blackdude716 wrote:Will you still be offering these over the winter? Im looking to grab a set before Christmas! Also how much of a drop can I achieve with these on a 93 urs4?
Yes, send me a pm
You will be able to go as low as you want - the physical limitation is the control arms and the bottom of the car. And of course shock travel.
blackghost
Post by blackghost »
I know I am raising the dead here. I figure posting this might help others aside from having a private side convo.
My question for Ed and anyone else to chime in: Would this work to raise the car another 2 inches over stock? I want to lift my avant! With your experience modifying the struts, are there any issues/limitations aside from getting a longer travel insert (bilstein HD)? I might start a separate post, but why not go straight to the source..
THANKS!
Running any kind of aftermarket camber plates won't help with lifting the car. You'll need a spacer of sorts to space where the spring mounts away from the plate. These will actually help with lowering.
