Danny boy's 20v 7a turbo of death build!
type85
Post by type85 »
Been cruising this forum for a couple/three years, Motorgeek is dead and full of spam, so I might as well post my latest project on here:
As you can see in my sig, I have 2 '84 Audi's one is the street legal coupe with an N/A 2.6L 20v running 034 1C and E85, I track it more than I drive it on the street, I decided to go full racecar hence the 4000q R.C.O.D. (racecar of death!). Here's an old build thread going back three + years on the car: https://grassrootsmotorsports.com/forum ... 328/page1/
The basic setup: suspension, brakes, drivetrain, interior, safety (it'll need a new cage at some point), is done. So the last major step is the engine!
Vital stats on the build:
300-350 reliable whp (350-400 crank hp). on E85, track only so will always be running it hard and at full boost! I'm really after minimal lag, big flat torque curve.
Car with driver should weight about 2,700lbs.
Early (?) 7a (it came with a header instead of the cast manifold), stock rods and pistons, ARP rod bolts, basic rebuild, hone, rings, coated bearings, valve job, 3B water manifold machining (HANK!!) on head, block drilled for turbo oil return line, ARP head studs. Currently have steel head gasket, considering doing a comp. dropping gasket to 9.5:1 or 9:1
3B intake, 3B valve cover, 3" downpipe with 5 bolt T3 flange (thanks Wiley!), two 034 "crack 'o matic" welded tube header with T3 flange (thanks Jim and Wiley!), 034 mount bracket, stock wastegate with 2bar spring (thanks Jim), 044 hi flow fuel pump, 60# injectors, 034 1C, 034 aluminum flywheel.
Yet to be purchased/decided: turbo: GT2871R (do I need the anti surge housing?) T3 flange 5 bolt outlet
Intercooler size and placement
boost controller: looking at the Innovate SCG-1 http://www.innovatemotorsports.com/products/scg1.php
Crankcase vent system/catchcan
clutch, spec stage 2+?
Re: Danny boy's 20v 7a turbo of death build!
Post by AudiSport4000 »
Oh shit, Garza!!! Glad to see you post here ;)
type85
Post by type85 »
AudiSport4000 wrote:Oh shit, Garza!!! Glad to see you post here ;)
Jus' trying to keep it real Mikey!!!
I gotta post where the big boys hang out so I can get the right advice!!!
type85
Post by type85 »
type85
Post by type85 »
varia
Post by varia »
looks clean!
¯\_(ツ)_/¯
project 2226
Ooo shiny
loxxrider wrote:Ooo shiny
I was gonna say this earlier today but got beat to the punch lol
Looking great man! Wish I had the means to blast parts on my own.
Is it going to be done by April 1st? ;) Looking good though.
type85
Post by type85 »
What happens on Apr. 1st. Biggest fella???
Spring Mountain!
type85
Post by type85 »
audifreakjim wrote:Spring Mountain!
Ahhh...... :-( no dice, only about a week away, maybe something local in late April with the coupe.
BTW, I'm looking for some ARP rod bolts, ARP is out, you know of any sources??
034?
2Bennett?
EuroSpec?
They should all be local suppliers with a good line on what you need...
That is, to say nothing of others like:
IMS
EFI-Express
FRP
Integrated Engineering as well.
Why do you need rod bolts anyways? Using stock rods? They usually come with aftermarket rods. That's one way to get them :)
type85
Post by type85 »
audifreakjim wrote:Why do you need rod bolts anyways? Using stock rods? They usually come with aftermarket rods. That's one way to get them :)
Stock rods and pistons, insurance policy: ARP head bolts, steel head gasket, ARP rod bolts, coated bearings and E85!
BTW, I called my bro's at Techtonics, they had ARP's for the 16v, same as the 7A, $139 shipped!!
Cool
type85
Post by type85 »
audifreakjim wrote:Cool
Waddya think big fella? GT2871, the "crack 'O matic" 034 header, 3" downpipe, 15psi, E85... 350horse?
Yeah, easily
type85
Post by type85 »
Why not do rods as insurance while you've got everything apart?
type85
Post by type85 »
alxdgr8 wrote:Why not do rods as insurance while you've got everything apart?
My understanding is, at the power levels I want, it's not worth the xtra $600 to $1,000
Also, If I do rods, then I might as well do pistons... another $1,000
You must have better self control than most people here then if you'll be able to keep from wanting more power! :D
varia
Post by varia »
for some reason i though its a 3b block with 3b internals, but its not.
you like to live on the edge if you gonna run:
7a stock rods and pistons, and 300-350 reliable whp (350-400 crank hp). on E85, track only so will always be running it hard and at full boost!
but time will tell
¯\_(ツ)_/¯
project 2226
type85
Post by type85 »
My plan is 300-350 Crank HP.
Eventually, I want to qualify for NASA "GTS" series, it's all based on power to weight, so might actually have to tune DOWN the engine to meet the 10:1 weight to power ratio for my class (2,700lbs.=270whp)!
