VEMS oil pressure input?
vwnut8392
Post by vwnut8392 »
is there a way to input oil pressure from a sending unit to a VEMS ECU? just curious because i would like to have that in my data logs and displayed on the on screen dash. i have a VDO gauge running off of a factory URS4 sending unit in my car already but its hard to watch it when im hammering the hell out of the car.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
Re: VEMS oil pressure input?
I am using one of these for fuel and oil monitoring
http://www.amazon.com/Auto-Meter-2246-P ... B000CIH39Q
vwnut8392
Post by vwnut8392 »
audifreakjim wrote:I am using one of these for fuel and oil monitoring
128.00 for a sending unit?!?! holy crap! i was hoping to just tie into my current OEM VDO sender and just run that signal into the VEMS if possible.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Stay tuned I'll be doing just that... I'll be logging both oil and fuel pressure in my next iteration of Rubi... I'll post up the details in my thread
vwnut8392
Post by vwnut8392 »
Good stuff! Ill keep an eye out plus ill work on fingering it out when I have time to mess with that car.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
VEMs needs 0-5v. The original senders just vary resistance so you would need to build a circuit to convert that to a 5v signal
