please educate me on VEMS trigger errors
vwnut8392
Post by vwnut8392 »
please someone educate me on the trigger errors, what causes them and how to diagnose them outside of trigger logger. please dont just post a link to the explanation on the VEMStune web site because thats so vague its not even funny.
i get this already but it answers not a single real question.
No Tr Error: no trigger error detected.
Too many Pr.trig: too many primary triggers detected (secondary trigger can be missing).
Less Pr.trig: less primary trigger detected than it should be.
Too many Sec.trig: too many secondary trigger detected than it should be.
Less many Sec.trig: less secondary trigger detected than it should be.
Sec trig pos bad: secondary trigger detected on bad position according to sectrig validation (to disable it just set minimum to zero and maximum to 360. at Secondary trigger settings).
Tooth length bad: the tooth width seems to be wrong (only if Advanced filter is enabled).
im setup with pretty much what the PNP ECU's are using all the stock AAN sensors on both crank and cam. my car ran totally fine and gradually started messing up. i think i found a trend in the problem finally as well as it does it more when the engine is cold and less when the engine is at operating temperature. so educate me on why these triggers happen and what causes them and how to trouble shoot/diagnose them.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
vwnut8392
Re: please educate me on VEMS trigger errors
Post by vwnut8392 »
34 views and no one???
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
So you are getting all of those errors or just looking for an explanation of the errors?
audifreakjim wrote:So you are getting all of those errors or just looking for an explanation of the errors?
His last response to the problem was this...
"well after all the hair pulling, screaming and swearing the problem is solved. i took my jumper harness apart and decided to pin out the whole thing and document it in a spreadsheet for easier referencing in the future and i realized that i never consolidated the grounds together in the harness and i was missing a ground from pin 17 on the EC18 connector. so i tied all the grounds together and added a wire to pin 17 on EC18. the grounds on the motronic connector i tied together are 10-14-19-30-48. the trigger log is still a little bit wonky at higher RPM but it doesnt complain about errors and it rev's good now. thanks again Marc Swanson for being patient and helping me, also thanks to everyone else who gave input including Klein Heribert who suggested the motronic pin 48 grounding because you was super close to the problem."
He posted on various forums, so I just copy/pasted it here for those seeking a resolution...
https://www.facebook.com/groups/vemsusers/
vwnut8392
Post by vwnut8392 »
thanks mushasho, i was just getting to posting what i did to resolve the issue. i 've been out playing with my car and scaring the crap out of myself since its finally running right :lol: .
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
