Oil temp senders for B3 factory gauges
Are there any alternatives to the giant temp sensor that came on the original I5 oil pumps? I found this one, looks like it's from the V8 quattro. This would be much easier to tap in somewhere.
http://www.ecstuning.com/ES283135/?gcli ... Ark48P8HAQ
yodasfro
Re: Oil temp senders for B3 factory gauges
Post by yodasfro »
049919563B is used on the V6
Perfect! So one would assume the resistance range is similar to the original i5. I can boil some water and compare.
yodasfro
Post by yodasfro »
The values for checking the b3/b4 I5 and V6 gauge with the factory tool vw1301 are same so I'd say they are the same. The V8 repair manual doesn't have those values but rather just a resistance/temperature comparison chart.
Namreg Rac
Post by Namreg Rac »
I would be concerned with how that temp sensor would effect AAN/3B pressure control valve in the oil pump.
Sean Haynes
Anchorage Alaska
The idea is to replace that huge temperature sensor since I don't have the pump anymore:) the one yodasfro recommended was perfect.
