HPR -- Small Chassis Rear Dif Center Bushing Mount
I will have the pre-order price sometime Monday or Tuesday after my poly manufacturer gets back to me with quote information. I made a few prototypes for customers (including Greene on here) and they are very nice.
As you will see in the pictures, I designed these to be used with the factory inner sleeve. I did this in order to retain wall thickness and maintain the overall integrity of the housing (think cracked housings due to 03junk)
Removal of the factory rubber crap is relatively easy with a torch. Just be sure to do it outside. Be sure to clean the sleeve well and remove all the old rubber. DO NOT MELT OR REMOVE THE INNER SLEEVE
This is the end all be all problem solver for your clunking rear dif!!!
Projected Retail Price: $60
Projected Pre-order price: $55 + free shipping
Looking for 10-12 orders total to help offset the mold costs.
Peters
Re: HPR -- Small Chassis Rear Dif Center Bushing Mount
Post by Peters »
Jared: can these be replaced without removing the rear subframe from the car?
yes they can as long as you drop the rear dif on its own. I do not recommend trying to heat the rubber out of the mount with it still attached to the car considering it sits underneath fuel lines
