I see this as a relatively inexpensive solution to 5lug front hubs, and if the donor car had UFO brakes, I could run anything that fits a B5 S4 (thinking TTRS here)... correct me if I am wrong.
Spring and damper issues would not be of concern since I would convert the housings to coilovers, likely with shorter koni motorsport inserts. This might sound like I am cheaping out on the foundation, only to spend way more on everything else...
So does anyone know if this would even be possible?
Would strut angle be an issue?
What about balljoint size?
TIA
