58 tooth trigger wheel dimensions
max
Post by max »
new member here looking for a trigger diameter under 7" and larger than 6". I'm doing a V12 engine to get rid of the distributor system. Appreciate any advice.
Max
Re: 58 tooth trigger wheel dimensions
your needs seem pretty specific. I know of 6" and 7" universal wheels but for something inbetween you are probably stuck having one custom cut. wouldn't be horribly expensive, $200 I'd wager at most for a qty 1 run at a local waterjet/laser shop.
