So. I've never used carbon fiber in my life. With that being said. I need help in choosing what thickness sheet I need to be purchasing off the interwebz, because I am clueless.
Going to be used as a dash display piece and then as a spot for a switch panel and some other gauges in the center of the dash where all the creature comfort and other boring shit used to be.
Here's the dash layout
posted from a computer in my pants
ChrisAudi80 wrote:Are you going dry or pre-preg, Jon?
If dry, don't forget about the resin thickness.
Well. To be honest. I was just looking to buy a finished sheet of carbon fiber and then cut out the shape on a water jet. I'm not sure what that would fall under with what you mentioned above.
I see. You mean you will buy a flat sheet of CF already finished with resin. Dry CF is just the cloth, pre-preg is CF cloth with the resin soaked in and packed in a bag. Once you take it out it starts to cure. You will also need to shape it and an autoclave for pre-preg. Its the stuff Koenigsegg use.
hot damn thats loot! fleabay is cheaper FYI. hell for that much i may just get one of the kits and make my own size flat sheets.
I figured, just an example of what you are looking for.
Now let's make a pre-preg dash
after my half assed attempt at a fiberglass dash last year, i wouldnt even want to fathom what it would take to get a nice looking mold for a carbon fiber dash.
