Have you ever tried to bolt an MK3 accessory bracket to an early 1.8l block and realize that you can only use 3 of the 4 bolt holes? well me and my friend came up with a solution to that problem and that is our adapter block. if your making some decent power out of your engine and you have your accessory bracket bolted on by only 3 bolts im sure you have cracked the bracket or the belt slipped off at least once. well the problem is without all 4 holes being used to fasten the bracket the accessory belt bracket twists under power which is not good. i am selling these at 45.00 shipped in the USA, over seas shipping will see additional shipping fee's.
84 4000S quattro-AAN swapped 83 UR quattro 95 URS6 avant 95 URS6 sedan 90 90 sedan-AAN swapped 91 200 20V turbo 92 GTI VR6 92 GTI G60 X-flow turbo 86 16V jetta coupe
Only problem with that is not every single early block has those 2 mounting tabs This is a solution that I have: Not sure if you are catering to the v-belt guys but a simple spacer with the upper right water pump bolt being secured by a counter sunk SC screw does the trick. HTH
