Possibly for sale- 1990 audi coupe Quattro
Kuma
Post by Kuma »
034 solid billet front and rear subframe bushings
034 7A fuel injector upgrade kit
034 JHM Solid Billet aluminum short throw shifter
new control arm bushings all around
new Power Flex front sway bar bushings(poly)
new sway bar end links all around
new ball joints all around
new trans mounts
newish motor mounts
two new front tires
New Power Flex rear diff bushing (polyurethane) needs to be installed
Momo hub adapter with Marine Momo steering wheel (needs a different one, but it works, so...)horn button(needs hooked up)
new used Nology plug wires
New dizzy cap
new fuel pump and filter
repaired broken fuel lines under the car.
Depo Clear Corner lens
B4 hood swap, with proper core supports center and outer, and B4 headlights wired up
new head unit has USB and Audio port.
all of the vacuum lines have been repaired up till the next one pops or breaks
new drivers side window regulator( needs to be installed)
new used intake boot
new secondary radiator
recent coolant flush and oil change( will get another oil change before sale)
has a power steering leak, i just dont know where from. its not horrible, but it is noticeable
needs new a new drivers side CV joint.I have a replacement drivers axle that i havent rebuilt yet, but will if needed. I have extra outer CV boots new in box as well.
brake bomb is shot
new battery
needs new brake pads and rotors. i have brake caliper rebuild kits available for only 2 calipers though.
Just did the timing belt which includes the water pump, t belt, coolant, thermostat, water pump, and pulley. including in the sale a spare FPR and MAF
the car has WELL OVER 250,000 miles. before i got it, it was serviced mainly at Reisu Motorsports in Houston Tx. I know the owner before me well, and if there are any things that you need to know i can call and ask him.
high flow cat( brand new) and has a custom side exhaust and Flowmaster Muffler. It comes out on the passenger side and really gets those tailgaters who want to pass you an earful. **** their hearing.
the car leaks in hard rain. dont like it, by a towel. ring it out later.
the odometer doesnt work
the fuel gauge sometimes works. If it reads a quarter tank of gas, i usually stop and fill up.
the passenger seat doesnt move forward or backward, but the seat reclines, backwards but nor forwards...
the drivers seat moves forward and backwards but doesnt recline, it used to work, but a buddy was in the car and was acting like a dumbass and he broke my seat. it may actually just be disconnected, but i havent checked.
i have newer 1997 cabrio mirrors that come with the sale.
the car used to be Alpine white, and i have within the last 6 months painted the car with Rustoleum Satin Green paint, and a roll on brush. Its durable. If you are going for looks, this car is not for you. if you are going for daily driving with amazing mileage, kill yourself. (i keed)
has black interior rear quarter panels and black door cards and handles.
I also just got new lower door trim pieces to install, the doors ones are done, but i havent replaced the other smaller portions, i will include those in the sale as well.
Crack in the lower portion of the already warped windshield.
is currently registered and inspected recently, so its good for another year.
i have to keep my tags because the DV tags are non transferable.
my asking price is 3000$ OBO
i am trying to sell this car so i can buy my Buddys B3 TDI swapped Passat wagen.
email for pics.
for an additional 250$ i will include an extra rear bumper, cold air intake, spare front control arms( need new bushings), rear sway bar, ECU, stud conversion kit(4 studs are already on the car, but it started to rain so i didnt get to finish installing the others), spare right side tail light, extra speakers, steering wheel and airbag and some other odds and ends if i find them.
Re: Possibly for sale- 1990 audi coupe Quattro
With all you've been through on this car, I hope you've got a nice upgrade in mind!
Kuma
Post by Kuma »
i have my eyes on a friends B3 Passat Wagen with an AHU TDI swap in it.
650-750 miles to a tank!!!
Kuma
Post by Kuma »
i will sell the coupe for 2400$ with stock fuel injectors and stock shifter
Kuma
Post by Kuma »
tomorrow i am going to rebuild the drivers axle and install new CV boot. Passenger side will get a new CV boot as well.
will trade car plus a nice handgun.
its wagon
Kuma
Post by Kuma »
yep.
Kuma
Post by Kuma »
passenger axle needs new inner and outer boots.
the drivers axle has been replaced and has a new outer CV boot.
Kuma
Post by Kuma »
bump
