Part of the ugh was realizing that the WK is simply a dead end, being the goofy (in 2010) 2.1 with solid lifters that parts are scarce to nonexistent for. I still have the valvetrain, reciprocating assembly, and exhaust manifold/downpipe from that engine.
Enter the MC2. "Drop it in" turned into "eh, do the head gasket while it's out". If I'm pulling the head, it's getting 034 exhaust valves, so I order those. I already had an ARP head stud set for a Corrado G60, so I acquired two more studs/washers/nuts to make a five cylinder set. Engine came with no flywheel, so I drive out to western Michigan to pick up an MC1 flywheel/clutch. I also picked up an ur-S4 intercooler and an ur-Q igloo.
In the three years between then and now, I found that the head that was on the engine was warped so badly that it needed to be cut .017 to get flat again. Nope! So I get a JT head and start porting. And porting. And porting. Most of the seriously long project time is because I had way more other fires to put out. My RX-7 is my true calling and it gets the attention.
I was most of the way done when Jonathan offered me a deal on something different, so I went that route. It recieved... less extensive porting. The ports looked beautiful compared to the JT casting so I spent a lot less time on it.
THAT head was completed as of a couple weeks ago. Getting ready to put it on. Scrape the block's deck down to cleanliness after leaving the head gasket on there as damage/rust prevention, and UGH. Cracked deck. It looks like someone did a head gasket and didn't blow the coolant out of the head bolt holes, and hydrauliced a bolt. I have pictures somewhere but not uploaded yet.
Pick up another engine for its block. It came from a long list of people in the local Audi community but hadn't been run for a long time. Pull the head, and it's an MC1 not MC2! Cool, 7.8 pistons for another time. Then I look in cylinder #1 and it's rust. And rust. And more rust. It might clean up at 82mm overbore, but I'm not about to buy pistons and machine time when I can source another block. O'ell. The inside of the engine was clean as could be at least, and the head had NO cracks between the seats! Too bad I have no use for it at the moment.
Around this time, I start running into difficulty sourcing the (shockingly expensive!) intake air temp sensor that the MAC-14 needs. It's a PTC sensor, not NTC, so I can't just adapt a GM sensor or something. I discovered it while paring down the wiring harness for the MAC-14 install into B2 chassis. My plan WAS to use the chassis-side fuel pump control and leave the MAC-14 out of the loop as far as tach and fuel pump control is concerned. No worry about fuel cut if it can't cut fuel in the first place
But the temp sensor thing had me bummed. I speak about it with my employer and he points out that it is probably not wise to rely on a car for which parts can be so frustratingly difficult to find.
That's when I realize that the fuel distributor MIGHT be gunked up like the one in my GTI is, and the one in the Quantum currently is (which is why it has run on four cylinders for pretty much the entire 100,000mi or so that I've owned it) and there's so many other variables and I just want to finish the damn car so I can drive it...
Project creep!
Speaking of the GTI, I decided that I'm going to adapt GM electronics to the car. Engine, instrument cluster, everything will be like the car is pretending to be a '01ish Cavalier. Should be pretty trick.
