Where I have Been / Cam Pulleys
Engine building advice and Q&A with Jeff!
Re: Where I have Been / Cam Pulleys
Or this damage could have been from the cam breaking and valves hitting pistons. I know a lot of the time in the TDI world if you toss a timing belt you need to look at the lifters for stress cracks (which are lightweight lifters BTW, exact same dia and weight as the lightweight ones sold for AAN). Most of the time people just replace everything in the head because they don't want to drop a valve or lifter later and do it all again.
amd is the best
Post by amd is the best »
chaloux wrote:Or this damage could have been from the cam breaking and valves hitting pistons. I know a lot of the time in the TDI world if you toss a timing belt you need to look at the lifters for stress cracks (which are lightweight lifters BTW, exact same dia and weight as the lightweight ones sold for AAN). Most of the time people just replace everything in the head because they don't want to drop a valve or lifter later and do it all again.
I said the same thing but it was an exhaust valve. Exhaust valves can't hit the pistons.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
oya
yodasfro
Post by yodasfro »
Is it possible the cams being billet vs. stock regrinds like what they should be for the 1002305 to be the issue? On 034's site all the billet cat cams are say recommended for solid lifters.
Rennkafer
Post by Rennkafer »
I've seen lifter bores that were damaged bored oversized and sleeved... possible? Would save you a ton of money if so.
Bill J
'12 GTI
'88 90 Quattro
'13 Mazda 3 (wife mobile)
2001 Chevy Express 3500
and two tube chassis in progress, Mid-engine 07K '73 Beetle, and Miata powered Locost
FRP
Post by FRP »
Unfortunately the center wall between the lifter bores is too thin to allow for sleeving. I sure studied it hard though.
weld / machine repair? worth at least getting an estimate.
scubagli
Post by scubagli »
Marc wrote:weld / machine repair? worth at least getting an estimate.
That's what I was thinking.
