Cory's Lifted / Rallyx CQ - Winch Installed
frostyflax17
Re: Frosty's RallyX CQ
Post by frostyflax17 »
Been a bit since i've updated. Been busy working on my garage renovation.
Finished installing the b3 90 1 piece bumper. Needed the bumper, the shock mounts, the side brackets from the fender transplanted onto the cq fender, and some trimming of the bumper.
Brush Bar fitment off an xterra. Just needs some cutting and brackets welded on.
Right now i'm working on resealing the tail lights, i swear i did it before (maybe it was a different cq i did it on?) but apparently its leaking. Bought some butyl rubber to redo it soon.
Cory
11 Touareg TDI - Daily
91 CQ - Lifted Rallyx Mudder
90 CQ - 3.0T Rombotis
90 CQ - Wannabe S2
91 200 3b - restore and sell
frostyflax17
So I decided to go to 40's in a bag for the first time, the coupe needed a lot of stuff done so I was just going to ride with friends. Something made me change my mind though and decided last minute to try to get the coupe on the road.
registered and insured it on friday about 4pm.
6pm the surgery began;
lifted suspension so there's about a 5" tire-fender gap
turned the offset solid mounts to max caster and then eyeballed the alignment (i got close, turned out to have slight toe in, camber was very close)
resealed both tail lights
put rear interior all back in
got the stereo working again (hardly used it thanks to lovely 5pot noises)
wired up turn signals in the rs2 lights temporarily
painted the tsw imola wheel center disc and nut
did a bunch of other lil things.
4am the surgery ended.
drove the car to wally world 10 miles away to get a new bulb for the tail light, drove it back. "Thought" i torqued down all the wheels (i might have been a little tired). Then got ready and drove an hour and a half away to meet up with friends, then drive 3hrs to the show. Sadly i only made it another hour and a nasty shaking started from the front right so we immediately pulled over and looked at the passenger front wheel, couldn't figure it out so we left the car and I hopped in my friends chevy 3800 turbo volvo's back seat with no seatbelts and road to the show fearing for my life lol. After the show my friends dropped me off to the car and we quickly realized that the front left wheel was loose, so we tightened it up and test drove it and it was fixed. I was swearing up a storm that i didn't get to take the car to the show because of loose lug bolts.
Anyways, the car drove pretty well for the 4hrs i driven it so well. Needs a proper alignment and some other things.
to do list for carlisle:
install my dual round votex lights
finish speedline wheels, mount bfg all terrain tires
modify inner fenders for clearance with the tires
install allroad fender flares
center driveshaft carrier
lower rear subframe 1" with new bushings for control arms
fix any other rubbing issues
**MAY finish 3" lifted coilover suspension** it's probably not smart to attempt to rush that and then cripple myself for the show
**MAY finish mounting the brush guard** need money for fab time
pics!
4/5 speedline wheels didn't come out so well with the plastic bolts, so i removed them and will be installing black anodized aluminum ones
1/5 of the speedline wheels came out fine, so this will be the spare mounted on top of the roof basket.
Cory
90 CQ - Wannabe S2
Dan McBoost
Post by Dan McBoost »
Dont forget, I said, "Are you sure your lugs were torqued?"
:P
Dan McBoost
frostyflax17
Haha yeah you did, and we checked the wheel that we felt the vibration on. I thought I tightened them all down :(
Cory
90 CQ - Wannabe S2
frostyflax17
Re: Cory's Lifted/Rallyx CQ
here's where i'm at right now.
beefy tires <3 (ignore the fact that there is no bolts or center caps right now)
to do list before carlisle:
install wheel bolts
pickup offroad lights off a friend and mount them somehow
alignment
inspection
install votex lights
take the car mudding
load it up with way too much crap.
Cory
90 CQ - Wannabe S2
LeafBox
Re: Cory's Lifted/Rallyx CQ - Carlisle Prep!
Post by LeafBox »
Mount the lights on the front of the roof-rack :D
A1QSHIP
Post by A1QSHIP »
Mount a couple of LED light bars both front :drive: & back :guns: on that roof rack.
Nulla tenaci invia est via
frostyflax17
Re: Cory's Lifted / Rallyx CQ
Well I was waiting for george's photos cause i heard he took a lot at carlisle, but alas i want to update lol.
got the car aligned nicely
installed the votex's and cleaned it up some. first trip to the gas station with it and i made a friend.
Loaded her up for carlisle and off i went. (only half installed the wheel bolts)
some pics at carlisle, thanks to grillage for the nicer photos than my phone could take lol
only hiccups were my fuel level sender decided to eat its grounding wire (quick fix from frank from canada helped).
odometer/tripometer decided to stop working (waiting on a new gear from george)
coolant gauge in cluster intermittently reads now.
the rest of the stuff i knew about already.
needs fixing list:
cluster issues
driveshaft carrier bearing
rubbing of tires on mudflaps
headliner and sunroof panel
upgrade list:
install hella offroad lights
brush bar
vems with plug and play from marc
forced induction with e85
lift it with spacers like kirks
Paint
Cory
90 CQ - Wannabe S2
frostyflax17
so a bit of an update, I took a welding class and decided to start work on mounting the brush bar i had laying around. I took some 6" 3/8" aluminum angle and cut 4" pieces to weld to the existing aluminum crash bar on the coupe.
clamped up
Alloy mig welded with a spool gun, instructor said i did pretty damn well for a first timer.
put the brush bar on to check for fitment, nice tight fit.
next step was to cut the bumper so that the brackets would slide through. Also mounted up the fog lights to the front.
one thing i definitely didn't like was how bulky the brush bar looks on the car, i didn't like the top bar that was on there, not how much metal there was towards the bottom.
so i cut the top bar off and made some nice cuts on the bottom that should work with the skid plate once i get it bent up right.
much more slimmed down
Then i went to the local cars and coffee and dan mcboost just happened to take some nice photos of the car. woot woot.
Next step was to mount the winch. I took some of the same 3/8" angle aluminum and cut out a piece that was roughly 3.5" by 1' to brace the back of the crash bar to then drill through and mount the winch. Better safe than sorry when my crash bar buckles and rips off with 5000lbs pulling on it.
came out pretty decent, used my new miller syncrowave 210 welder. Lotsa of chatting with loxxrider about which welder to buy.
I thought it would be funny to take the car to waterfest and park the car in the show field up on a stump. It was pretty well received next to all of the lowered stanced cars.
There was a golf country there owned by Jaime from orchid euro, these are the cars that inspired me to make my coupe the way it is. So of course i had to go take some pictures next to it with my cellphone lol
to do list in this order:
aluminum 1/4" fairing to mount the offroad lights to
wire up offroad lights and winch
lift car using spacers
skid plate
repaint and body work
upgrade the motor (hopefully by this point my 200 will be sold and I can get vems from marc)
Some other updates to the garage since the winter.
got a new 56" toolbox (harbor freight but its built pretty damn nice for the price)
lateral/vertical band saw (harbor freight again)
portable welding table (ok, maybe i went a lil crazy at harbor freight)
and finally my new welder, the miller syncrowave 210, it's a tig welder with mig process option. plenty of power and versatility to do what i plan on doing. Also picked up a watercooler and watercooled torch plus a whole bunch of other accessories. (this is why i couldn't afford the vems anymore lol)
Last edited by frostyflax17 on Tue Jul 19, 2016 11:47 pm, edited 5 times in total.
Cory
90 CQ - Wannabe S2
It's about time you updated this... :P
Re: Cory's Lifted / Rallyx CQ - Winch Installed
Glad to see a new post finally! I have to say, it's so much more satisfying reading a logical progression of explanation and pictures here than seeing a pic of a brush guard here, and a new wheel there on Facebook.
I think you'll be really happy with that welder and it was good seeing you at Carlisle and waterfest! Just too bad my time was limited both times!
I knew you'd need to lift it more after that silly golf country made the cq look short lol
I'll just put this here. 8-)
Dan McBoost
Spent time time with Cory and the coupes together today.
1920x
1920x
1920x
Dan McBoost
Seeing Corey's CQ next to yours is funny! Both look awesome, but such a dramatic difference in style!
What a nice contrast :)
frostyflax17
heck yeah, love this so much.
Cory
90 CQ - Wannabe S2
frostyflax17
things are happening... again
Cory
90 CQ - Wannabe S2
The "5 years later" update! Haha! Good to see you posting again.
