Hi All,
Been a bit since I sent the parts off to paint
I'm really happy with the way everything turned out!
I had a local audi enthusiast do a little photo shoot here in Cincinnati and I'm really really happy with the results:
Also, I started working on that last 5% list...
Tackled the Air Conditioning this weekend. The Air blows super cold for a while now but it has been causing idle issues when it kicks on and causes the car to die at just about every stop when AC is engaged.
So after some guidance from Marc, I have the issue pretty much solved. I had to create a Table B in VEMS with a higher duty cycle curve and idle than the normal map and then trigger VEMS to switch when the AC compressor is engaged.
I tapped into the power feed from the AC Clutch Relay to the AC Clutch via the green and yellow wire in Tq5 pin 3 -- the green 5 pin connector on the auxillary relay board.
I connected that to another relay to pin 85, then pin 86 to chassis ground.
When the AC Clutch is energized, the path from pins 30 and 87 on the new relay is connected. I used sensor ground for one side, and the other end goes into one of the analog inputs in VEMS - in this case Pin EC18-6.
A little setup in VEMS and voila! AC is running and not stalling! I drove the car to work this morning in cool comfort!
