Aan throttle body and vems.
vinniepearl
Post by vinniepearl »
I'm running vems in my aan swapped coupe. I'm trying to find the proper connector for the throttle position sensor as I dont have the aan harness. Does anyone know where I can source the connector?
Also, I need to wire up the tps to work with vems. Which pins do I need to utilize? Would I better off using an entirely different throttlebody?
Sent from my SM-G892A using Tapatalk
Re: Aan throttle body and vems.
Post by Afterthought »
What intake manifold do you have in the car currently? If its an AAN manifold I'd use the AAN throttle body/TPS since you wouldn't need an adapter to run it.
the plug, I was looking for it at one point, the PN is 025 906 238 B is the number for the female/ harness side of plug .
The AAN TB does work well with vems and calibration is easy. I don't have the pinout handy but I think its on the S2Forum
vinniepearl
Thanks marc! Didnt realize it was on your website. I'll search for the pinout on the s2 forum.
vinniepearl
Assuming I dont need to use the throttle closed part, just pin 1 2 and 3. Looks like pin 3 would be the wiper which would run into vems? Image
vinniepearl
vinniepearl wrote:Assuming I dont need to use the throttle closed part, just pin 1 2 and 3. Looks like pin 3 would be the wiper which would run into vems? Image
Pin 3 - ec36 - 1
Pin 1 - ec36 - 29
Pin 2 - sensor ground
