And my helper... not really, but he likes hanging out in the car.
Good to know on the noise and heavy steering, I did look at the mr2 pump when doing my preliminary research but wanted to install a new more modern pump. I still haven’t 100% decided on the electric pump route. If I do it I think I will be putting the pump in the back (under) the car... going to spend some time on the fuel system this weekend I think to figure out space. I’v also looked at upgrading the bomb to a modern lightweight accumulator...Grillage wrote:This project is great!
on the subject of Electric Power steering - I used a later MR2 pump when I did my old V8 coupe. You can see the progress here:
http://theprojectpad.com/viewtopic.php? ... &start=350
It was a good - not great solution.
certainly had power steering but it was a little heavy and the pumps are noisy
Manifold looks nice. I’m convinced that these cars sound so much cooler through a tubular manifold !FFF wrote:Moving parts around so thought I would throw a couple of snapshots up. Certainly not the first time Hanks work has been posted but it’s hard not to stare at the art.
And old vs new (Xona 8267)
Miraculously the bomb is leaking... I am however looking at keeping the hydraulic assist - currently looking at a few different composite accumulators to replace it with - also looking at an electric power steering pump, need to decide sooner than later...Afterthought wrote:The underside looks really good . I always thought that the cars up there suffered .
I don’t know if you mentioned it already but if you plan to do anything with that brake bomb , do it now ! Easiest time to work on the rack and stuff
Should say isn’t...FFF wrote:Afterthought wrote:The underside looks really good . I always thought that the cars up there suffered .
Looks one of the relay/fuse panels. I have one in my 80.PRY4SNO wrote: What's that 034 module... IIc?
Just the fuel pump relays to run these...PRY4SNO wrote:Lots of double posts with Tapatalk, eh?
Did the carbon fibre backing plate come with the Infinity Box?
Oh and no the carbon fibre plate was leftover from another projectPRY4SNO wrote:Lots of double posts with Tapatalk, eh?
