Sam's 20vt CQ - Red and PNWy
Re: Sam's 20vt CQ - Red and Broken
Congrats on the wedding Sam,
Would love to see this at BBQ again, but I guess I can tolerate a GTI as well, god knows it'll smoke me.
Well, I did a thing. I solved the issue with the exhaust manifold/turbo by selling the whole setup, and buying an open box EFR7163 on eBay for $1125. I need to come up with a header and downpipe, but to get into the ideal option for $130 is pretty cool. Not sure how I scored it, they must have had the title listed poorly.
It's the nice turbo with the integrated BPV and T4 twin scroll IWG hotside. The plan is to set things up for a spool valve, though that will probably added sometime down the road due to the cost. I'm excited, as cost aside this is the ideal turbo--the same power as I had before but with much better response.
There are some other things that crossed my mind to prep for BBQ as well. I need to do brakes since the stockers I have now are worn out (I think I have a sticky caliper), and I should finish the upgrade I'd had sitting on the shelf for years. I have some 996TT calipers and just need rotors and brackets. However, due to the dimensions this is a tricky/relatively expensive caliper to build a kit around, so I'm debating selling them and stepping down to a more common/cheaper 996 Carrera setup. I figure if I can sell my 996TT setup with new pads for $600-700, that should pay for the entirety of a smaller set and make it a net zero dollar move, which is something important in this post-wedding lifestyle.
Sam
Sam
Sam Stone
Right on. Glad you were able to get that turbo. I looked back at my coleman quote and its pushing $800 to do two piece rotors. And the 996tt pads are about $100 more than the 996 pads.
Update time, the good, bad, and ugly edition.
Rolling back to early September, I had a complete motor to rebuild including finding a good set of OEM 3B/AAN pistons, receiving a cylinder head that Hank and Jim conspired to set me up with, and figuring out an installation for the EFR7163 I had just received. I got to work, hoping to avoid stress and scramble of BBQ6 by having the car together and driving something like a week before the event. Ha ha ha, yeah right.
The solved the header issue by ordering one from Iroz. I seriously considered building my own, but when I added up material costs and factored in the learning curve of making a collector, primaries, welding everything, and the logistics of getting everything together to come up with packaging...spending $1200 to buy a product proven to last, make power, and be easy to work with became the obvious choice. I ran up to Vegas on October 1 to pick up the completed header and cylinder head to get started.
The piston issue was a bit of a struggle. I had previously had my bottom end balanced together, and wanted to make sure that was maintained when replacing my burnt #5 piston with the new build. I procured a little digital scale that measures to .1g, and got to measuring my old set of pistons and a complete new set I got off of Facebook. I found each sets of pistons to be well-matched within themselves, with a spread of about 0.8g between the lightest and heaviest piston in each set. However, the two sets weighed an average of about 6g different from each other. Visually and dimensionally I could not tell any difference between them aside from a small 'nub' of material on the wrist pin boss, and the heavier set having a '+' stamped into the crown while the lighter set had a '-'. I tried grinding away at the heavy set trying to get one within 1g of the average of the lighter one, but it turns out aluminum is not very dense and after removing more material than I was comfortable with from the wrist pin bosses and lower skirt, I had only removed around 2.5g from the lightest of the 'heavy' set. No bueno.
I put the feelers out again, and found a local guy with an AAN shortblock that had '-' marked pistons. I paid $100 for it and thought I stole it for that price as it came with a good damper machined for a 60-2 trigger wheel, an oil pan, and the block itself was totally rust free. Unfortunately I found it did have a scored #4 bore, so it wasn't useable this go around. However, I found a piston that was within 1g of my four old pistons, so I was in business. I started assembling the motor at 10pm October 9, 11 days before we were to depart for BBQ. It turns out these motors are pretty simple to put together, with all the parts fully prepped I think I had about 6-7 hours of labor into completely assembling a longblock. I was surprised, having been used to Porsche engines taking a solid 20-30hr of assembly in the day job.
The engine went in the car October 12, and focus immediately turned towards getting the new turbo/exhaust installed and packaged. The Iroz header is well designed to make it easy to package and intake and exhaust in a small car, but the reality is that the EFR is just a really long turbo. Long hotside for the IWG, long CHRA, and long compressor housing because of the integrated BPV, all adds up to a turbo that is almost 11" long. In addition, the 7163 does not use an anti-surge compressor housing, instead using a 2.50" OD inlet. Nobody makes tight radius 'cobra head' hoses with a 2.5" ID on the 'turbo' side, so you're stuck using a full size elbow which is VERY tight against the back of an RS2 headlight. Initially there was a large interference, but I moved the engine and trans as far back as they would go on the motor mounts. It should have been there anyways for reasons, but at some point during all the engine/trans swaps it ended up being quite far forward. I got almost an 3/4" of frontal clearance by doing this and it made the turbo inlet a lot more workable. This was completed Saturday, October 15, less than a week before BBQ7.
At that point, I felt comfortable moving ahead with the rest of the installation, which included making turbo oil and coolant lines, the exhaust, and intake. For the turbo lines, I went with brand new black anodized fittings and black nylon covered hose and topped it with black fire sleeve. It looks great, but the black fire sleeve does tend to attract a lot of dust. I used VIbrant for some of the fittings, which I would not recommend as they were a pain in the ass to put together as they don't have the lefthand threads in the collet like other brands do. I made them work, though.
For the exhaust and other fabrication, I went with Ryan of Jakey Products in Phoenix, AZ. Jakey develops and builds exhausts and headers for us at Evolution Motorsports. I really like how he does things and he has an awesome shop. He practically begged me to have him build a new exhaust for the car at a great price. It was to be a full mandrel bent, TIG-welded 304-stainless turboback system using a muffler he builds in house. Can't say no to that. Car went to him Sunday, October 16, five days before leaving for BBQ7.
He spent about two full days building everything, and the system turned out beautiful. The downpipe has about four bends in it, going between the engine, trans, frame rail, and axle with more than an inch of clearance everywhere. The center and rear sections are fairly straight forward, with solid hangers and lots of clearance everywhere.
He also built a new turbo discharge pipe, and turbo inlet pipe, both out of aluminum. The discharge pipe fits extremely well, having about three bends in it to conform to the space available. The turbo inlet is a work of art, transitioning from 2.5" to 4.5" through a pair of compound bends to mate up to one of our large, dry element V-Flow conical filters and its matching venturi. It fits down right next to the intercooler, in a perfect spot exposed to lots of cool air but protected from dirt/water by the bumper. He made it up by eyeballing it in about 30min, and it is a piece I would be truly challenged to make myself. Anyone in the southwest looking for quality fabrication, Jakey Products' number is 602-687-8270 and he will do you right.
Ryan finished the exhaust on Tuesday, October 18 but needed the car the next day to finish some minor details. I stayed late on Tuesday night to get the car fired. I filled oil and coolant, cranked over to get good oil pressure, and then installed plugs and connected coils and injectors to start the car. It fired up, but had a wicked lifter tick and ran on four cylinders. Total dead miss that I narrowed to cyl 5 with a wet spark plug. I did a ghetto compression test by hitting the starter with the plugs in and injectors disconnected, and there was an obvious skip from a cylinder with low/no compression. Dejected, I went home at 11:30pm, believing I may have bent a pair of intake valves, as I turned the engine over by hand with the cams off a tooth during assembly and ran into interference.
Wednesday rolled around and I got to work. My dad flew in at noon to join me for the weekend, and I informed him that we were preparing to pull the cylinder head to replace some valves. I ordered a head gasket kit and a pair of 323mm A8 brake rotors to allow installation of my 996 C2 brakes...because why not? We rented a compression tester, loaded the car up from Ryan's shop, and prepared to do the maybe-possible-definitely-difficult 36 hours before we were destined to leave for Vegas. We got home at 7:30pm, had dinner, and got to work with a compression test before everything came apart. The results were 90psi, 90psi, 90psi, 90psi, and 90psi...wtf? The low results were not unexpected given a brand new motor and questionable rental tester, but they were even! I threw the plugs back in and the engine purred to life.
. 20 minutes later we were rolling around, breaking in the new engine. An hour later that was done and all looked well. No leaks, no drips, no issues...just 7psi of boost with the wastegate backed almost all the way off.
Thursday, the day before departure, I went to work while my dad stayed home and did some odd jobs. The EGT probe got connected, blower motor replaced, and he started work on doing the BBK. I got off work, and we changed the oil and worked on the BBK for a while longer. We ran into an issue not having long enough M12x1.25 hardened bolts to secure the new caliper brackets to the uprights, so we had to backtrack a bit and put the stock G60s back on. I ordered bolts off of McMaster Carr after the event and everything else is ready to go when I get around to it. Calipers are 996 C2 bought off eBay for $400/pr with almost new pads, rotors are Brembo 25644 purchased from Autohaus AZ, which are 323x30mm rotors with internal venting. They were about $100/ea. The calipers will need paint eventually, but most of them do.
Anyways, with that we gave the car a good wash and left for Vegas around noon Phoenix time on Friday.
It was pretty hot, as the car doesn't have A/C or even tinted windows and it was in the low 90s. We kept the ventilation moving and it wasn't awful, but not very comfortable. I did barely any tuning, mostly increasing WGDC to get a little more boost (about 15psi is all I got electronically without messing with the wastegate), but it was a little off. The car ran a little warm as a result, but never overheated. We hauled ass from Kingman to Vegas in a good pack of cars, doing 95-100mph the whole way.
Thanks Alex K of Vex Art for another set of awesome event photos!!!
We arrived at Audi Henderson a little ahead of everyone else with a screaming power steering pump. I guess running along at 4500rpm must have bled the power steering or something. A $25 bottle of power steering fluid later, the reservoir was filled but it was making some nasty noises like the pump was dead. I noticed a little puddle of power steering fluid under the front of the car further showing issues. I thought about cutting the belt but my dad talked me out of it, which was good.
I might be preaching to the choir a bit, but Battleborn Quattro is truly an amazing event. It is so cool to be able to get together with a bunch of great people from around the country to hang out and share our passions, then go enjoy them as a group for a day is a highlight of my year. The event is quite casual and well-paced, and the last two years I've done things I never would have known about before and will cherish the experiences for life. It is well worth the money, blood, sweat, and tears for anybody reading this to make their way out to the event, even if it's to ride with someone else--it will be a pretty cool ride in something you'll appreciate.
Anyways, we got a good night's rest at the hotel, and got up early the next morning to run out to Cars'n'coffee at Speed Vegas southwest of town. Speed Vegas is an exotic car experience, with a half dozen fancy cars and a road course to drive them on. Hosting CnC there is genius as you get a bunch of gearheads standing next to a track watching cool cars run around. Excellent sales tactic. On our way to and from the event we did some light tuning, getting full throttle fueling dialed in and boost raised up to peak around 20psi, though tapering heavily to 14-15 on a wastegate actuator that is too soft for high boost use. EFR users, buy the Turbosmart part. I was beginning to be very pleased with the EFR, in 4th and 5th gears it makes 1bar by 3500rpm (without spool valve at this time), and the transient response is VERY good. Once the power it's capable of comes in, I should be very happy in how it achieves my goals--power of my old 30R with much better response.
At some point during the morning, the power steering pump went silent and stopped leaking. Seal conditioner in the $25 power steering fluid? Not sure, but not complaining.
This year's BBQ7 drive was up and down Mt Charleston, which is north of Las Vegas about an hour. We had a great drive out to the mountain, punctuated by a small threshold braking issue by a participant. The drive up the mountain was fairly leisurely, not quite the same pace as what we did last year in the Valley of Fire with Ben and Wiley, but a great drive all the same. Definitely gave everyone's standalone tune a workout coping with altitude (~8000ft). I dealt with this last year driving back through Flagstaff at 7000', so everything worked great and the car had no issues all day. Saturday evening was steins of beer at Hofbrau Haus with the whole party. Jim, Brendan, Wiley, Peter, Marc, and Hank are excellent drinking (or not in Hank's case) buddies.
The next day my dad and I ran through the Valley of Fire, and then I swapped seats so he could drive home while I tuned. I made some good progress with tuning and got driveability way up and engine temps down. With the wastegate cranked down and 95% WGDC, I got a peak of just over 20psi which made the midrange VERY punchy at freeway speeds. We made it home no problem and grabbed the best Mexican cuisine in Phoenix.
I spent the next few days getting caught up with work, but drove the car on Thursday intending to turn up the wick and enjoy it a bit. After hours I took it out with my coworker Matt and ripped around our industrial complex for about 30min. We were having a blast and the car was running great when all the sudden it made a huge backfire and then a horrible banging noise. Motor died, no compression while cranking. Fck. A quick autopsy found that the cam gear bolt had broken in two, causing the cam gear to break and presumably hosing the top end that had six days and ~800 miles of use on it.
I posted this on Facebook and conjecture flew. That bolt is one-time-use! It must have been overtorqued! Use aftermarket bolts! Ten years ago I would have believed all of that, but since then I'm pretty diligent when it comes to carefully assembling this stuff per factory specs. This bolt had been in and out a number of times, but had never been overtorqued and as far as I've known is not a common failure point/wear item. I was pretty puzzled, but dropped it for a couple weeks while I went on my honeymoon and worked on my business.
This week I finally got a chance to get the car home and tear it down, and got some hard answers. The good news is that the failure makes total sense, but the bad news is I caused it by screwing up the assembly. I mentioned before i had to retime the cams during assembly as they were put together a tooth off. Well, it appears that when I did that, admittedly pretty tired and exhausted by my full time job and the task ahead of me, I neglected to torque down the exhaust cam caps. One of the nuts came off and got wedged between a cam lobe and the head casting, which presumably caused the cams to bind up, gear to fail, and bolt to break. Fortunately, this appears to have happened pretty suddenly, as only two intake valves bent despite the engine having been at 5000rpm when the failure happened. I have a head full of good intake valves in the garage, so I'm home free, right?
Unfortunately, I found some much worse news while cleaning up the bottom end. The #2 cylinder bore has a huge scratch in it that can only be explained by a problem with the wrist pin circlip--either the clip or the wrist pin are wearing into the cylinder wall. The damage is pretty deep, estimate 0.5mm. Game over for this fresh bottom end, and I either need a new 81mm block to put a set of OEM pistons in, or I need to nut up to bore one of the two blocks I have, buy some pistons, and rebalance everything. Neither is cheap, and as the holidays are coming up and I'm still recouping from the major build I just got done doing, this project goes on the back burner for a few months. Woe is me.
So, if anyone has a line on a good 81mm block in the southwest, let me know. Until then, 11 months until BBQ8!
Sam
Sam
Sam Stone
As always, really enjoy your write ups. Lots to learn and consider, or file away for later, "when I get to that point."
With the Turbosmart WG actuator, that only applies to the integrated WG turbos, correct?
What caliper bracket did you use? I goofed and bought the RS2 bracket from Apikol/034 and needed to shim it ~3mm with the same calipers (996 C2 / 986 BoxsterS).
This got a bit rushed as it was ~3 months of stuff to follow up on and it's Thanksgiving. I'll add in more details if I think of them.PRY4SNO wrote:As always, really enjoy your write ups. Lots to learn and consider, or file away for later, "when I get to that point."
Borg Warner sells a 'high boost' actuator that is probably ideal, but all the turbos are sold with the 'medium boost' actuator. With the large flapper size and short lever arm, it takes a strong actuator spring to keep the wastegate closed--which is good for keeping turbos alive under warranty, but bad for making boost. Anyways, I believe the consensus is that if you're buying a new wastegate actuator, might as well buy one that is adjustable hence the Turbosmart recommendation.
I found the caliper brackets in a box of prototype parts from work. I believe they were designed for using the 996 C2 calipers with 312mm rotors on a B5 A4 or Mi4 VW as part of an old BBK kit. I use those brackets along with a 5mm waterjet caliper spacer to line up perfectly with these 323mm rotors.
Sam
Sam Stone
Dang man it was great meeting you Sam sorry to hear that you had another issue. I need to find a source for that bolt for both my cars. I would recommend ditching the factory gear too. I have had a couple of the little teeth break off on me luckily not causing any damage .
Sam do you recall if they sell those actuators in different lengths? I need to move my actuator to avoid a clearance issue in my coupe.
When I put this back together I'll use a new factory bolt and washer. I think the failure was because of all the torque required to spin the cams with the nut in the way, rather than any shortcoming in the gear or the bolt. I've broken cam gears before, but it was due to assembly issues like putting cam caps in the wrong order. If you do it right and torque the bolt, it's perfectly reliable.Afterthought wrote:Dang man it was great meeting you Sam sorry to hear that you had another issue. I need to find a source for that bolt for both my cars. I would recommend ditching the factory gear too. I have had a couple of the little teeth break off on me luckily not causing any damage .
I think it would be challenging to find a 'shorter' actuator. Due to the size of the hotside, you're always going to have the actuator hanging off the side of the turbo. The BW instruction sheet does say you can position the actuator so the bracket is held on with only two of the three bolts, which is important with how the Iroz header has things clock. But if you're out of clearance aside from that, you might have some bigger problems to solve.
Sam
Sam Stone
Fantastic write-up! Bbq and your build and process all sounded fantastic. Sorry to hear about the head dying... And the block dying. We have a block or 8, but a bit far away.
I agree that the failure of the bolt was probably caused by the nut wedding between the cam and the block. But I still stand by my opinion that the bolt should be replaced every time it is torqued. It may not be tty, but I don't know for sure and it isn't worth taking a chance on. Of course, in this case, a new bolt wouldn't have helped.
Sorry this all happened. I feel for you! I've already blown up two engines this year and I dreamed that I blew another one up last night lol. It's been a bad year for me with cars too. But give yourself some rest and dream of efr goodness and your motivation will come back!
Love the write up Sam,
Hate the failure.
Serious bummer.
Hate the failure.
Serious bummer.
Any new updates?
I've had a couple close calls finding good engines/blocks. Haven't pulled the trigger on anything yet. I picked up a nasty mountain biking habit that has been sucking up free time and money. Still, I've realized I almost forget what it's like to drive a super fun old Audi and it makes me really miss it. These cars were a huge part of my life in years past, and can continue to be in the future. So I'm definitely going to fix it this year.
In other news, I am now the proud owner of half of Evolution Motorsports. So far that has been a giant challenge and responsibility, but the future is in my own hands.
Sam
Sam
Sam Stone
Congrats Sam!
For planning to get the Coupe back in the mix and for the new opportunity/responsibly!
Wiley Rankin Coffin
Mine
'87 Alpine White 4KQT e85 Xona - Toy
'16 Deep Black Pearl Golf R Manual - Stockish
Hers
'06 Deep Sea Blue 2.0T A4 APR Stage 1
- ringbearer
Congratulations! Owning old needy Audi’s is good practice for owning a business, they both always need work! Good luck with both
Now that the car can be a write-off I'm sure we'll see all sorts of updates rolling in, in no time
Congrats on the business opportunity, that's a major development!
Holy shit, that's awesome on the business purchase, congratulations!
Congrats Sam!!!!
Wow Sam, that is awesome! Congrats man, you're going to kill it!
wow, Sam, congrats on the business venture.
Awesome news!
That would be a dream! Amazing... congratulations!
Alex notiied me that I haven't logged onto here in...forever. I thought I wrote a BBQ update but guess not.
First things first...BBQ5 or 6? BBQ 2018!
I himmed and hawed for a while about what to do with the Audi last year. Lack of motivation to do anything with it, combined with missing the experience of driving it. For a good portion of my life, I'd travel around beating the crap out of my red 5cyl Audi every single day. Since moving to AZ, those experiences got really rare. I felt like I was missing part of my identity that way, but also had other priorities and time sucks come up in my life that put it on the backburner. Since it wasn't adding anything to my life (but not really costing anything except for a garage stall) I wasn't sure if I'd fix it, sell it, or part it out. I still didn't have a good 81mm block, hadn't put together a budget to bore a motor out and buy some pistons, and eventually sat around for too long to get that done in time for BBQ (I figured 6-8 weeks for parts and machine shop time to do it right).
Well, last October Jim comes into town and we go on a bike ride. This is like three weeks before BBQ 2018. He tells me I should fix my car. I had a good looking stock 7A bottom end I'd gotten in a horse trade, and decided to throw it in with stacked head gaskets. I figured having a car I could run and drive at low boost was better than one I couldn't do anything with. My wife was spending two months in the PWN doing residency auditions, leaving the weekend before BBQ, so I figured the car and event would be a good distraction while she was out of town.
Two weeks before BBQ I get my shit together and get going on assembling the car. I grabbed two intake valves and lapped them into the new head. I got a new OEM cam gear and bolt from Micah. I got the engine hoist and bought a new engine stand, and ordered a gasket kit. I pulled the old shortblock out of the car to remove parts to transfer to the new motor. Goal was to have the engine assembled and ready to go in the car before driving her up to Portland, leaving me five days to get it in the car and running. Easy!
I had attened BBQ twice before. In each instance, the car was completed within 5 hours of departure after at least a week of very late, long nights of work. This year was to be no exception.
I jumped through some hurdles that week before the event, sourcing the turbo coolant freeze plug to install in the 7A block, drilling the oil drain port, and modifying the head gaskets for the turbo dowel position. All was good the Thursday night before I left for Portland. I went to go torque the cam caps down, being careful to make sure the cams were timed correctly and that all the nuts were torqued, as the cam nut backing off is what killed the motor last time. Everything was good until I got to the final nut, the one that came off in 2016. I torqued it...or tried to. Stud snapped off in the head! Balls! That explains why the nut backed off--the stud was stretched in a prior life, so it never held clamping force. Still, this was a huge pain in the ass given I was getting back into town Tuesday afternoon before BBQ and now had to do some major work to get the engine together before it could go in the car.
For those unaware, the cam studs are a special stepped stud, and M7x1.00 thread. I spent like $90 on an M7x1.00 helicoil kit and shipping to have when I arrived back home.
My friend Brian May smelled adventure and flew out to help me thrash the car together. He got in Wednesday and we got down to work on drilling out the stud, installing the helicoil, and finishing the motor. The thread repair was fairly easy. I grabbed a spare cam cap to use as a drill guide which worked well. There was a bit of a drama as the helicoil inserts I had were shorter than the depth of the hole in the head, meaning first go around the stepped stud went in too deep to install a nut once finished. I lucked out by cutting down a second insert and managing to install it above the first, with them butting right up against each other. This allowed the stud to go in at near-factory height and button everyting up. Mission accomplished!
Except...when we assembled it and went to go turn everything over, there were some MAJOR stiff spots at the top of each cylinder. I think it was either lifters or the 82.5mm pistons rubbing the AAN head gaskets, but it was not great. While testing, with the cam bolt and crank bolts not torqued due to not being installed in the car where I could hold them, I managed to break the keyway in the OEM cam gear on Wednesday night before BBQ. It was officially turning into a big shitshow at this point.
We stepped back a bit. Pulled the cams out and turned over the bottom end. It was tight but eventually smoothed most of the way out. I spun the bottom end to a point where nothing was at TDC and spun the cams over with the bolt and those spun freely too. So that hurdle was...passable, but I needed to figure out something for the cam gear.
I wasn't going to let the event fail. I'd lost a bunch of sleep working late, Brian had flown out, and I'd told my buddies I would see them in Las Vegas. I also wasn't in love with the idea of spending more than $200 to buy a cam gear and have someone send it overnight for Friday (penny wise, pound foolish?). So against the better advice of everyone I asked about it, I took the cam and cam gear to work. Cleaned them up, lined the cam gear up precisely with the keyway in the cam, and filled the void with JB Weld. I let it harden for a while, then torqued the cam bolt down. The ghetto ass keyway held the gear in place during that, so I moved ahead with reassembling the engine and putting it in the car.
We ended up working all evening deep into the night finishing assembly and getting it into the car. We had to remake some fuel lines and solve some mysteries from the car having been apart for two years. But around 4:30am Friday morning it was ready to go. I primed it to get oil pressure, then we installed the plugs. It fired RIGHT up and ran very smoothly, but made the most unholy mechanical noise I've ever heard. Like 95db horrible mechanical clatter from what sounded like the top half of the engine. We started and ran it a couple times to see if we could identify it or if it went away, but it was constant and horrible. Defeated, we went to bed.
I went into work a half day on Friday and talked it over. A number of Audi people mentioned they had similar experiences when running cars that had sat for a long period of time and that it was just lifter tick. It was the first time I'd put an engine together without soaking the lifters in a can of oil for a day, so it seemed plausible. Brian finished assembling the car with bumpers, topping off fluids, etc. and we went for a drive after I got home. After a few trips around the block, it was better but still bad. Then it got a little better, and a little better. I got the confidence to go drive the car outside the neighborhood, so we hopped on the freeway and went to the parts store to get materials for an oil change. By the time we got there, it was a noisy engine but not the worst I'd ever had, so I decided we'd go to Vegas early Saturday morning to catch up with the group on their way to breakfast.
Changing the oil worked wonders. Almost immediately after we fired it up, the engine quieted WAY down. We went for some rips around the block and got to bed by 10.
Next morning, we woke up at 5am or something and hit the road. After 20min of 80mph freeway driving with CQ gearing, the lifter noise vanished and the car drove great. We made REALLY good time to Vegas, under 4hr from Phoenix, and met up with the group on their way up Mt Charleston in time for Breakfast. No shenanigans this year which was sort of a relief given we were exhausted.
We stayed at the Hard Rock Hotel, which is an awesome BBQ spot. It's kitty corner from the Hofbrauhaus, is cheap, has nice rooms, and a killer bar. It was the weekend of Halloween AND Dia de los Muertos so a few of us took in the sights at the hotel bar after dinner. Good times.
Brian and I took the scenic road home, hitting Route 66 between Kingman and Seligman before taking the back way through Chino Valley/Prescott. It was a beautiful day and the car was completely trouble free.
Since then I haven't done a lot with the car. I finally got rid of the stock front brakes, and installed a 321mm A8+996 C2 Caliper front brake setup. I did that to try and get rid of some nasty issues with locking rear brakes, which I thought was due to having S8 rears on there. The new brakes are great, but didn't fix that issue. Pretty sure I have way too much rear rebound damping and the rear tires are simply lifting off the ground when turning in.
Hans (spike_rally) came to town and we went for a good rip out to Barlett Lake NE of Phoenix. There are some really fun roads there and we could open the car up. He got some video, the car sounds amazing: https://www.facebook.com/albyno883/vide ... 40/?type=3
Which brings us to today. I haven't driven it in a few months, as I had to rob the battery and some parts for other projects. However, I need to get back on it as I have a big change ahead! My wife graduates med school this month, and has taken a residency at the University of Washington in Seattle. I will be moving up there along with my business! Plans for that are coming together, needless to say it's been a stressful and hard six weeks since we found out and the next six to eight weeks will be just as bad getting everything wrapped up and moving.
However, Seattle is going to be awesome, and one of the biggest things I'm looking forward to is diving into a large and active crew of old Audi people again. Alex has been my gateway drug into the scene up there, and whiel I should have paid attention to everyont there, I'm surprised and excited that so many Motorgeek/TPP members are up there. I have absolutely loved my time here in Arizona, but I never got to enjoy the Audi as there isn't a big support system for it here, and the type and environment does not suit a car like this well (high temps and long straight roads). WIth more friends nearby to share interest, parts, and projects with I'm hoping to get back into this heavily.
We have an awesome house lined up just east of Redmond. It has some land and a two car detached garage--something to at least keep the Coupe out of the rain when I'm not driving it. The driveway is so large I'd love to host a little gtg or barbeque out there as well. We should be moved in by late June.
Sam
Sam
Sam Stone
