If not, I got the cool tools and mad skillz!! :-o
Re: Jim Green's 90q 20vt - 636whp 07k
Yeah... but, did you clean up yer intake runners and throttle body so you get an extra 5horse to add to the 800horse you already have??
Looks good Dan. The IM is already perfect, and my head is stock. At some point I may build a head with cams, valves and porting, but it's pretty necessary at this point. Doing that would require a larger clutch, fuel pump and injectors. They are all running at ~85-90% capacity currently.
Thanks!audifreakjim wrote:Looks good Dan. The IM is already perfect, and my head is stock. At some point I may build a head with cams, valves and porting, but it's pretty necessary at this point. Doing that would require a larger clutch, fuel pump and injectors. They are all running at ~85-90% capacity currently.
Greg and I are coming over and we're installing one of those 34mm "IMSA" intake restrictors, that way, you can run the stock clutch and 87oct fuel!!!
Started the car this weekend on the new motor. Fluidamper is supposed to be here this week. Also going to miss our track day at spring mountain :( But thinking about thunderhill instead.
From Issam? I'll be interested to see how that works as the pulley on the front of my engine is less than pretty and I was thinking of getting the TT-RS version anyway.audifreakjim wrote: Fluidamper is supposed to be here this week.
Bill J
'12 GTI
'88 90 Quattro
'13 Mazda 3 (wife mobile)
2001 Chevy Express 3500
and two tube chassis in progress, Mid-engine 07K '73 Beetle, and Miata powered Locost
'12 GTI
'88 90 Quattro
Sweeeeeeeeeeeet!
Yeah, from Issam. It's easy for me to convert to 6-rib since I only have an alternator to drive. I have a TT-RS pulley that is spoken for, but I do need to sell it. They are fluidamper style as well, but originally designed for half my HP. Given the recent events, I am doing everything within reason to keep that flywheel from ever coming loose again. Loctite obliviously being step 1!
If the "spoken for" falls through, let me know. I'm also only running an alternator (1700lb cars don't need power steering) so I'll be keeping an eye on this. How are you running the alt/water pump, off of a jackshaft?audifreakjim wrote:Yeah, from Issam. It's easy for me to convert to 6-rib since I only have an alternator to drive. I have a TT-RS pulley that is spoken for, but I do need to sell it. They are fluidamper style as well, but originally designed for half my HP. Given the recent events, I am doing everything within reason to keep that flywheel from ever coming loose again. Loctite obliviously being step 1!
Bill J
'12 GTI
'88 90 Quattro
'12 GTI
'88 90 Quattro
Lol never mind on the water pump... I made it backwards to about page 99 and saw you were running a BMW electric pump. Didn't see if/where you said which BMW it was from though.
Bill J
'12 GTI
'88 90 Quattro
'12 GTI
'88 90 Quattro
335 turbo 6 style motor. They are known to fail every 40-50k miles. I keep a good used spare in the trunk that I picked up for real cheap. I figure any electric water pump is going to have similar lifespan. I have not figured out the speed control yet, it doesn't respond to PWM like the older BMW pumps are supposed to.
Hmmm, thinking I might build a jackshaft and use the stock pump since I don't need to move the alternator.audifreakjim wrote:335 turbo 6 style motor. They are known to fail every 40-50k miles. I keep a good used spare in the trunk that I picked up for real cheap. I figure any electric water pump is going to have similar lifespan. I have not figured out the speed control yet, it doesn't respond to PWM like the older BMW pumps are supposed to.
No issues with the stock pump you know of?
Bill J
'12 GTI
'88 90 Quattro
'12 GTI
'88 90 Quattro
Not that I have heard of.
Photo dump. Needed to address high speed stability of this beast:) Felt pretty good at 153mph!
https://youtu.be/rDB6GA7CiHE
Man, your car is looking great!
Yeah. Woooee. Love the number on the side
That is flat out amazing on so many levels.
lol @ "god damnit, I hate this fvcking turn!". tell us how you really feel.
I probably hate it because it's shaped like a penis. Or because this was pre-coffee
race PRE coffee?audifreakjim wrote: this was pre-coffee
you should see what LA traffic and an offer to go to Denny's does to him. its not pretty
Marc wrote:you should see what LA traffic and an offer to go to Denny's does to him. its not pretty
Hank does a great impression. I should go to therapy, but it's easier just to keep me feed and caffeinated.
audifreakjim wrote: just feed and caffeinate me.
Nice work on the diffuser, love the dividers. Please keep us posted on how well this works. Something like this is in my future.
So might as well come out with it: Would it be aaaaaalright if I copy ?
Mike
