Alex's V8 90QS : Cutting the cylinders in half
Re: Alex's V8 90QS : Cutting the cylinders in half
A few from the road
ImageP1150140 by Vex Art, on Flickr
ImageP1150134 by Vex Art, on Flickr
ImageP1150201 by Vex Art, on Flickr
ImageP1160020 by Vex Art, on Flickr
ImageP1160110 by Vex Art, on Flickr
ImageP1150977 by Vex Art, on Flickr
ImageP1160102 by Vex Art, on Flickr
ImageP1160307 by Vex Art, on Flickr
Grillage
Post by Grillage »
Great pics!
CURRENT
PAST
90quattrocoupe
Post by 90quattrocoupe »
^^^^^This
Not too much to update, I've been driving it a lot with no issues.
Forget if I ever posted an engine bay shot after it was running.
ImageIMG_20161119_135533 by Vex Art, on Flickr
The hockey puck mounts caused unbearable NVH, especially above 2500rpms. I'm not sure how I survived 3000 miles down and back to Vegas. I did order some of the orange practice pucks as suggested, but those felt even stiffer so they got returned. Decided to try B5 mounts which I had been thinking of doing years ago. Ordered some B5 RS4 (non-hydrualic) mounts and they work great installed upside down. Might be able to install them rightside up if you ground out enough of the B4 mount, but I couldn't be bothered. Did have to trim some off the thread of the driver's side bottom to prevent it from hitting the subframe, but that was easy. SOOO much better. No more body numbing vibrations at idle and ear bleeding drone at highway speeds. Exhaust still has a small amount of drone between 2-2500 rpm, but not bad.
Modified B4 mount (cut and pried out the OEM hydraulic mount; hole drilled in center):
ImageIMG_20161119_131605 by Vex Art, on Flickr
B5 RS4 mount installed upside down:
ImageIMG_20161119_131615 by Vex Art, on Flickr
Also swapped to all black tails for now:
ImageIMG_20161105_125741 by Vex Art, on Flickr
the german
Post by the german »
Clever solution on the engine mounts- did you have those done for the cruise the other day? I should have gone for a ride with you!
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
the german wrote:Clever solution on the engine mounts- did you have those done for the cruise the other day? I should have gone for a ride with you!
Yep, did them a few weeks ago. You should have
Post by vt10vt »
Damn! I thought for sure you'd be happier with the orange pucks. The 1.8t is a shaky bastard of an engine though, glad you found a solution you're happy with!
vt10vt wrote:Damn! I thought for sure you'd be happier with the orange pucks. The 1.8t is a shaky bastard of an engine though, glad you found a solution you're happy with!
I might have ordered the wrong ones, was hard to tell what's what on Amazon. The ones I got were super heavy and rock hard.
the german
Next time! I'll trade you drives ;)
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
I've apparently been driving with a bad MAF all this time. Was troubleshooting low boost issues and replaced a bunch of stuff (Swapped to 710N, new wastegate, swapped to K03S turbo), but it came around to just being the MAF. New used MAF and it pulls so much better! Probably gained a good 30-40hp.
90quattrocoupe
Nice.
Greg W.
Einbilden
Post by Einbilden »
Glad you got the maf figured out. Its nice to get red of the little nagging issues like that specially when there engine related.
Man I like all your projects and I love the way you infuse the factory look in your cars/engine bays.
