timing belt is on, cams all timed up. went to go tighten the cam caps and used the wrong spec. *snap*. !#$%$!^!^$%#$! :curses: :curses:
much more :curses: :curses: later and I managed to extract the broken stud, but I'm going to replace all the cam cap studs on the one cam I was tightening down as I'm sure I started to yield the other studs on that one. 'luckily' I only had started to tighten a few of them to the wrong spec. Sigh.
s2 on the way
audibing
got the replacement studs finally, $6.62 each ($8.27 list!) :-o
manifolds are bolted up and passenger side turbo torqued down with lock tabs engaged on the studs. the drivers side turbo will be installed once the engine is bolted up. I need to get some more turbo studs though, I ordered some but they never came in :(
working on getting a lift for my new garage but I will still get this car together so I dont have to tow it to my new house. Getting there..
WAUG0806
savagerocco
I am getting ready to do the fab work on my sedan and the PT motor. I was looking at the pictures of the mounts you had from the ABZ motor. Do those bolt to the PT block? They might make the install easier than the PT mounts. They aren't too much money according to etka but i haven't a clue if they will bolt to my motor. I am assuming that they are since you haven't made any mention of modifying the mounts for the 4.2 swap.
savagerocco
topic changed because the engine is in and it runs
Still some work to do though
One very not so nice surprise...when went to go fill the car up with coolant it started pissing out of seemingly everywhere. A little digging and discovered that my braided stainless lines must have rotted out
applying air pressure to them and bubbles were coming out of the middle of the lines and the fittings like one of those goddamn lawn sprinkler hoses. I'll cut one of the hoses open to see what happened.
for now I'm just going to run the turbos oil cooled with caps over the t's I built on the water pipe to feed the water jackets. no time to dick with it since I have a long drive coming up with the car on monday!
BradWeingartner
cuatrokoop
HT Motorsport
congrats on getting the motor in ad running Mark!
Sorry to hear about the braided lines, thats really weird. I agree with Brad though, you'll likely cook the turbos with no water in em, can you hack something together with copper etc?
Can't wait for a report on the change from the PT, I really think it should be significant.
Good luck with the drive.
H
H
RSCoupe
Toxcheap
BradWeingartner wrote:Most turbos designed for water cooling won't be real happy with dry water jackets. They aren't designed to allow the oil to do all the cooling and you might seize them up or do other damage.
It's a bummer but true... I hope you don't cook your turbos :tard:
Booooooooo bearer of bad news.
could be a good excuse to upgrade, though
RSCoupe wrote::stupid:
What brand s.s. lines are they? They should not rot out in only a couple years, especially not when used for coolant.
summit. I'm a little ticked.
Justin517
siena
