Brembo 4 piston calipers
Urtorsen
Post by Urtorsen »
SOLD
Audischwagon
Re: Brembo 4 piston calipers
Post by Audischwagon »
pm sent
Gr8 I r8 8/8.
86 - 5000 10vtq Warp Core BsS 2.2bar spring/Cruise control delete. "Time Dilator"
91 - Folksvagen GeLf 8v Crustaceous powered warp core/tachyon bilateral slip inhibitors for phase dilation enhancement.
Urtorsen
Post by Urtorsen »
Replied....,.,,Bump!!!
Urtorsen
Post by Urtorsen »
Bump. There is a company that makes a bracket to run these on golf mkiv/A3/TT chassis up front
Urtorsen
Post by Urtorsen »
Bump
Little confused... You're saying run these on the front? Are these 17z calipers or something smaller. Never read anything about anyone using the rears before.
ejg3855
Post by ejg3855 »
the pistons are sized incorrectly to use these as front calipers.
Urtorsen
Post by Urtorsen »
If you check the part number which I can supply, these calipers are recommended by a European company to be used with their adapters that fit on the front of mkiv chassis
Urtorsen
Post by Urtorsen »
themagellan wrote:Little confused... You're saying run these on the front? Are these 17z calipers or something smaller. Never read anything about anyone using the rears before.
Part numbers coincide with brembos used on front big brake kits on mkiv and other platforms
Urtorsen
Post by Urtorsen »
A1QSHIP
Post by A1QSHIP »
Can you post up the caliper piston sizes? For comparison, I know that on the 996 GT3 the rear calipers have cast in to them the part numbers that correspond to a front caliper for a Boxster, BoxsterS. However in that instance the caliper pistons are a different size for the rear of the GT3 than the Boxster application.
Chris
Nulla tenaci invia est via
Urtorsen
Post by Urtorsen »
No problem, I can do that in a few
Urtorsen
Post by Urtorsen »
I didn't push the piston out but the best measurement I can take from it and the track it leaves on the bad is 28mm per piston
Urtorsen
Post by Urtorsen »
Bump
ejg3855
Post by ejg3855 »
ejg3855 wrote:the pistons are sized incorrectly to use these as front calipers.
There may be some gains to be made from a pedal feel but these are still incorrectly sized. I don't care that some European company sells brackets so you bolt them on, that doesn't make it right.
I don't want to derail a FS thread, I just don't want someone to buy these thinking they are going to be significantly better than say G60's.
Assuming (4) 28mm pistons gives a effective piston area of 2460sq-mm'ss
G60's have a 40&45mm sized pistons which gives an effective piston area of 2845sq-mm's.
Brake force is directly related to surface area which the brake fluid pressure is being applied.
Urtorsen
Post by Urtorsen »
Ok thanks for clearing that up for us.i didn't realize this for sale section only caters to one particular platform, or make & model.
ejg3855
Post by ejg3855 »
I used G60's as an example.
Im just here for peoples safety, suggesting they do a bit of math before they just assume OHHH BREMBO BRAKES ARE MOAR BETTER.
nuugen
Post by nuugen »
I wouldn't mind having another set of these for the REAR of one of my projects. PM me please..
91 200 20v AAN swap
91 200 20v RS2'd daily
91 V8 5-spd 4.2
86 Scirocco VR6
90 CQ
95 S6
93 Eurovan
99 A6 da loaner
04 A4 Avant 3.0 6-spd
Urtorsen
Post by Urtorsen »
"Moar better" lol
Urtorsen
Post by Urtorsen »
Pm'd
Urtorsen
Post by Urtorsen »
Arent there advantages of a fixed caliper over sliding??
Urtorsen
Post by Urtorsen »
Bump
Urtorsen
Post by Urtorsen »
SOLD
