7A piston rings
type85
7A piston rings
Post by type85 »
Doing a rebuild on my 7a "T" project, looking for OEM 82.5mm rings (053 198 151 or 054 197 151B), all i can find are single piston sets for $140ea!, that's $700 for all 5, I could buy JE pistons for a little more that that! Is there a cheaper alternative?
The ring specs are 1.5mm, 1.75 (with the little "step") and 3mm for the oil control ring,
Pics of some of the action so far:
Re: 7A piston rings
I can do about half that on the rings, $70 per hole, hastings.
let me know.
type85
Re: 7A piston rings
Post by type85 »
Marc wrote:I can do about half that on the rings, $70 per hole, hastings.
let me know.
Thanks! I have 1 lead from Audifans on rings...
I am also interested in other items from your fine establishment:
20v fuel rail, stainless injector bungs, hardened crank timing gear, possibly coated bearings and even rods...?
Dan
90quattrocoupe
Re: 7A piston rings
Post by 90quattrocoupe »
Dan, I think I have a 7a fuel rail you can have for the cost of shipping. I will check.
Greg W.
Re: 7A piston rings
90quattrocoupe wrote:Dan, I think I have a 7a fuel rail you can have for the cost of shipping. I will check.
Greg W.
I was going to say the same thing. I'm about to throw one in the junk pile.
type85
Re: 7A piston rings
Post by type85 »
Greg W.
thanks!!
type85
Re: 7A piston rings
Post by type85 »
Greg W.
thanks too!! I'll take either one!
type85
Re: 7A piston rings
Post by type85 »
Got rings?? I noticed the second ring doesn't have the "step" in it like the OEM ring had....
type85
Re: 7A piston rings
Post by type85 »
Ohhh yeah... this also showed up in the mail today....
