So quick back story. A couple weeks ago the car started doing this thing where it would die during warmup. I never logged it (
) or really worried about it as it's been too cold and I've been too busy. Then a few days ago it started getting harder to start in the mornings, requiring a couple key cycles. Then yesterday it barely started and ran on 1 or 2 cylinders for a minute, died, restarted same way, required foot to keep it running, and then started running on all cylinders after a few minutes. Today it won't start. At all. I tried disabling the cam sensor in VEMS and taking the 50/50 shot at it starting, no dice after plenty of tries. Cam sensor seemed to be bad, I replaced it, new one seems to test out fine, nice 0-4.9v swing but still no start.
Attached is a trigger log, PLEASE HELP I'm about out of ideas and really don't know where to go from here in terms of diagnostics. The crank signal looks normal but I don't understand why I'm getting a.) 2x cam sync pulses and b.) I'm getting so many secondary trigger errors. Any help would be appreciated!
Config and other trigger logs attached in following posts.
