dana wrote:I know it seems crazy, but have you considered switching back to a regular OEM type radiator and fan with aux?
I had a very similar setup to this with the mishimoto radiator on my 90 with a big turbo and I was not satisfied with it. I ended up getting hank to make me a forward facing intake, and installed a ducted radiator in the OEM spot with an aux radiator, RS2 fan shroud and 200 20v fan. Was very happy with it after that.
I will have to look at your thread and see pics of what you were running.
I am feeling like the problem is not related to the radiator. What kind of temps were you seeing?
The issue with re-engineering the whole setup is:
1) cost: I dont have a stock radiator and new radiators are very expensive.
2) limited location: with the AAN intake manifold a stock coupe radiator is too wide, and I also dont have one. I have a very limited space to put the rad so I need to maximize flow as able.
I also want to make sure there is not something going on somewhere else before I go through the process of redesigning the whole thing. I can't fit one in front of the car unless maybe if I was to get a new intercooler and relocate that.
3) Most importantly, I never had a single issue controlling temps last summer, so what has changed?
