Dan's '93 UrS4
Re: Dan's '93 UrS4
Very impressive work Dan. Cant wait to see it in person with all the new stuff. I'll still haven't gotten a ride
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
- ringbearer
Re: Dan's '93 UrS4
Thanks, I'm doing all I can to have it ready for the drive this summer!
Re: Dan's '93 UrS4
Nice work, and as was noted on QW, good thinking on the grease nipples.
Makes me want to incorporate that into my coupe build now...
- ringbearer
Re: Dan's '93 UrS4
Thanks, I'll post the rear brake upgrade soon.
Re: Dan's '93 UrS4
hows the rear brakes coming along? I've been looking for a good rear big brake solution that wont throw the bias too far off...
- ringbearer
Re: Dan's '93 UrS4
This post has some info and pics. I made spacers and fitted everything and it looks good. I'll update next week, daughters birthday has taken over for now
http://forums.quattroworld.com/s4s6/thr ... tml#306977
- ringbearer
Re: Dan's '93 UrS4
Got the rear mostly done, trans swapped now getting front suspension back together. Decided to sell the house so I've got to get the car out of the garage
Pressure is on!
Pressure is on!
Re: Dan's '93 UrS4
Nice! Good motivation lol
- ringbearer
Re: Dan's '93 UrS4
Leaving it in the garage would devalue the house too much
Re: Dan's '93 UrS4
selling the house to finance the build?! this is getting out of hand!ringbearer wrote:Leaving it in the garage would devalue the house too much
- ringbearer
Re: Dan's '93 UrS4
Maybe I should buy a boat
- ringbearer
Re: Dan's '93 UrS4
I had an issue getting the shift linkage adjusted and it turned out I had installed the bushing in upside down that the Apikol SSK arm mounts in, they were out of cores so they sent me the parts and I did it myself, twice, lol. After getting it adjusted 1-2 is too tight, you really have to yank it out of 1st and 2nd. So I removed the linkage and tested it with the shift arm, still too tight. I should have done it before I installed it but live and learn. Dropped trans again and delivered it to JHM today for a full rebuild with carbon synchros and 4:1 center diff. I hope the rest of my "core" trans is in good shape, internal parts add up quick and I'm out of time and funds for this phase of the project. They are out of carbon synchros but hope to see them soon, fingers crossed...
Annual drive/GTG is in a month, I hope to have the S4 on the road!
Pic of shift pattern for testing purposes, please do yourself a favor and run through the gears before you get too serious!
20150525_194335 by ringbearer93, on Flickr
Pics of rear brakes
20150501_131319 by ringbearer93, on Flickr
20150423_134936 by ringbearer93, on Flickr
300mm still looks small with an 18 but good for what I need.
20150525_194335 by ringbearer93, on FlickrPics of rear brakes
20150423_134936 by ringbearer93, on Flickr300mm still looks small with an 18 but good for what I need.
Re: Dan's '93 UrS4
Which is why I'm going 310mm back there...ringbearer wrote:20150423_134936 by ringbearer93, on Flickr
Re: Dan's '93 UrS4
I'm about to undertake a suspension overhaul in the 200, thanks for the pics and detail. Great work here! I admire your Koni's!
Re: Dan's '93 UrS4
I'm sure the extra 10mm will make them look hugemushasho wrote:Which is why I'm going 310mm back there...
- ringbearer
Re: Dan's '93 UrS4
WOMBAT wrote:I'm about to undertake a suspension overhaul in the 200, thanks for the pics and detail. Great work here! I admire your Koni's!
Thanks! Lots of time and money, as always more of both than planned. It has been up in the air for about 7 months, I really need to drive it.
Re: Dan's '93 UrS4
I hear you. I've practically avoided driving the 200 because the bushings are so shot the car is a wandering death trap.. Finally have a bit of cash to replaced the failed components.
- ringbearer
Re: Dan's '93 UrS4
I was afraid of driving my daughter in it, I'm so sick of driving my suv kid hauler now that I will put her car seat in as soon as it has been proven safe
- ringbearer
Re: Dan's '93 UrS4
Had a really tight 1-2 shift collar in my new to me edu, ended up taking it to JHM for the full treatment and a couple extra.gears and the 3-4 shift collar. Too many dollars but it should be good for a long time.
So, it is officially getting close!
20150618_200354 by ringbearer93, on Flickr
Alignment hopefully next week and it may be done for a time.
20150618_200354 by ringbearer93, on FlickrAlignment hopefully next week and it may be done for a time.
- ringbearer
Re: Dan's '93 UrS4
20150619_144025 by ringbearer93, on FlickrMade it on the ground and a good 20 minute test drive. Everything felt really good, be better with all the wheels pointed the right way. Alignment Wednesday afternoon, fingers crossed...
I still don't quite believe that it drives again
Re: Dan's '93 UrS4
Woohoo!!! She's sitting pretty.
How long's it been since you got behind the wheel?
- ringbearer
Re: Dan's '93 UrS4
Thanks! , took it.down before thanksgiving
Re: Dan's '93 UrS4
That's killer news! Congrats!
Looking forward to driving impressions after your alignment.
- ringbearer
Re: Dan's '93 UrS4
I'm stoked, seems very flat in the corners, I was taking it easy but this is a whole new ballgame for me. Ride is very stiff, I need to back the shocks off a bit... Since I can
