derracuda wrote:i'm gonna bet that you get a lot of P/S harmonics with it mounted solidly to the fender well there
I ran out of that type of steel so thats only half the bracket.
Isolator bushings will be utilized :slap:
3bAudios wrote:nice to see your making some real progress Marc, can i get a ride when its done?
Alloutofdonuts wrote:I like the cut-out dealie on the exhaust, I want to do that with my rabbit project! Marc, do you know if an inspection station will raise hell with that?
Or are you going to do some sneaky V-bandage on the cut out? Sounds kinda redundant now that I think about it.
Oh, and anotha question, are those MR2 pumps compatable with ATF or only the green stuff? Sorry if this is buggering up your thread Marc, feel free to delete it :wink:
newt wrote:Is it done yet?![]()
Lookin like some good progress Marc! There should be a nice lil 'gauge' at your door any time now as well 8)
WAUG0806 wrote:Marc are you using steel or aluminum tubing for the intake pipes?
Jonathan wrote:Is that cut-out before or after the baffle? I used a spiral baffle in my brother's RX-7 TII and found 4-5 psi more boost when I removed it.
