01e oil cooler
quattro
01e oil cooler
Post by quattro »
The 01e I have bought for a project has pipes off it for an oil cooler, do I need to use a cooler or can I just loop the lines up?
quattro
Re: 01e oil cooler
Post by quattro »
Re: 01e oil cooler
I think the prudent question is, why wouldn't you use them?
quattro
Re: 01e oil cooler
Post by quattro »
Why does this one have it when my others don't?
Re: 01e oil cooler
I want those
Re: 01e oil cooler
its normally just tdi's and a few rare RS/S car boxes
sell me the pump and cover plate and ill get you cash and "nonpump " parts to make us both happy , pleaaaase I really need a pump for my race car
stin
Re: 01e oil cooler
Post by stin »
V8Q has that but its connected to side of engine coolant radiator.
Re: 01e oil cooler
WOMBAT wrote:I want those
Me too!
Or, at the very least... some detailed pics of the supply and return locations in the casing. Might be a worthwhile retrofit, down the road.
Re: 01e oil cooler
A lot of the benefit is just dumping fluid on the torsen back there. A loop is a lot of the gain and the pump 01e has more capacity. Unless outright race car or tow rig, I think you are good to loop.
quattro
Re: 01e oil cooler
Post by quattro »
Hank wrote:A lot of the benefit is just dumping fluid on the torsen back there. A loop is a lot of the gain and the pump 01e has more capacity. Unless outright race car or tow rig, I think you are good to loop.
Thanks for the info.
I'm converting my urs6 avant to a 2.5tdi 5cyl. Standard it only makes 103kw and 290nm@1900rpm.
This gearbox originally came from a 2.5tdi v6 b6 a4. It has a 3.89 ratio so I don't have to change my rear diff as the s6 was originally an auto.
