Freeing up AUX inputs in VEMS
So I'm attempting to find some extra aux inputs. Currently I believe they are all being used. both knock sensors, audi trigger setup, LC switch, Serial in, and I believe GPS in and one other. I'd like to add a config switching switch and possibly antilag, because, well why the hell not. I don't have my documents in front of me to tell me what aux is in what input and yada yada.
Am I able to just dump one of my knock sensors? from my understanding they don't even read the frequency of an i5 correctly on VEMS. From what I can tell some of the inputs are held up at 5 volts from inside the ecu already as well so I do not believe I can use those inputs, am I correct on that?
Ideally I'd like to switch to a 60-2 setup so that frees up one from the audi trigger setup as well.
88a5tq
Re: Freeing up AUX inputs in VEMS
Post by 88a5tq »
Hey Phil. Finally made it over here. Incidently found myself looking up this exact question basically. I'm surprised it doesn't have any replies! Well now that I have the COP conversion kit in my possession, I found myself wondering if it would interfere with my plans to use launch control. Then I came across this thread and suddenly am quite worried it will. Did you get any answers outside of this forum or in pm's? I already started putting together the parts to use for the launch control too. Oh well, let me know. Thanks
88a5tq
Post by 88a5tq »
Nevermind, Marc says its not going to be a problem.
In your case (88a5tq) the coils are using outputs, not inputs which is what this question is about.
Phil: if I were you I'd go down to one knock sensor, freeing up one analog input.
88a5tq
Post by 88a5tq »
That's a huge relief Marc! Thanks I was beginning to worry about the number of leads on the conversion harness versus the number of open terminals on the "Aux plug." I guess it wasn't too difficult for you to figure out I am Julian from the emails we have exchanged haha. Im so impatient I already ran all the wiring and harnesses for the COP and launch control. Im definitely ready to dive into vems :flag:
Oh and sorry phil for resurrecting your dead thread lol. Maybe you've been waiting that long for a definitive answer to your question though
Haha no worries on the thread res. Thanks for the info Marc. Once I actually do something to the car, I'll probably remove one knock sensor.
