WTB- 20v NF head
Audischwagon
WTB- 20v NF head
Looking for NF head to replace my mc1
Gr8 I r8 8/8.
86 - 5000 10vtq Warp Core BsS 2.2bar spring/Cruise control delete. "Time Dilator"
91 - Folksvagen GeLf 8v Crustaceous powered warp core/tachyon bilateral slip inhibitors for phase dilation enhancement.
Re: WTB- 20v NF head
You would be better off just throwing a set of SS 34mm exhaust valves in there to be honest
Old head is trashed, he is looking to replace it. You remember how that is dont you Taco...
yeah yeah.... That was my fault though for not paying attention to the backwards cam cap
I've done that...AngryTaco wrote:yeah yeah.... That was my fault though for not paying attention to the backwards cam cap
Audischwagon
Found nf head. Now what if I wanted to put ss valves in the nf head. Machining question...If I bought the 34 mm can I just lap them in? Or will I need to grind the seat/valve?
Gr8 I r8 8/8.
Audischwagon
Bingo....Raarrrrawwwwg!
Gr8 I r8 8/8.
You will need a light grind. The stock exhaust valves are 33.3 mm. You can use the stock OEM seats but they will need to be matched. Lapping isnt really necessary if you are throwing good same sized valves in. My machine shop doesnt like lapping valves due to the nature of the abrasives and I have never had a problem just throwing new valves in (same sized)Audischwagon wrote:Found nf head. Now what if I wanted to put ss valves in the nf head. Machining question...If I bought the 34 mm can I just lap them in? Or will I need to grind the seat/valve?
