Mid-Engine Quattro
Mid-Engine Quattro
:twisted:
Stumbled on some interesting images which brought me back to the old mid engine urQ thread in the archives.
http://racingcars.wikidot.com/audi-sport-quattro-s2
Looks like the rear driveshaft is driven off of the "front" of a traditional Audi transaxle and depicted as going through the oil pan and the front seems to have a gearbox to fix the rotation.
Re: Mid-Engine Quattro
Stunning.
Why route the intake over the exhaust manifold and turbo when the shortest (and least hot) path is on the passenger side?
That looks like the shortest boost routing.
Anyway, I posted this on S2Forum and figured I'd repost here: Something that I considered in the past for a mid-engined 4x4 was using a FWD engine and transmission turned sideways for front and rear outputs. Of course, for going slowly offroad having the additional reduction of the FWD final drive is desired but could be an issue for going fast onroad. Also, you'd have to make sure everything was spinning on the correct direction. I'd use one of the new 07k I5s from a rabbit or jetta and, maybe, DSG B) Hank, how much for an 07K with DSG?
Post by ChrisAudi80 »
I think this was going to be the follow up on the S1 before Group B got canned.
PRA4WX
Post by PRA4WX »
Mcstiff wrote:That looks like the shortest boost routing.
I don't see how you would get around the gear reduction?
Well, you can set up a quickchange diff to have a <2:1 ratio. That is with 4.11s so using 2 or 3.x ring and pinions could help more. Not sure what the highest final drive you could fit into a FWD trans is.
"Max" torque 550nm so not quite enough for a built mid-engined urQuattro. Maybe the Cayenne GTS is better.
SEStone
Post by SEStone »
The Cayenne/Touareg drivetrain is a monster. Dropping it out of the truck is like unbolting a small car in terms of weight/bulk.
Sam Stone
This may seem obvious but the ATTESA E-TS in the GTR looks very similar the the mid-engined urQ above, aside from the use of a torque tube to keep it front engined.
I'd be cool to run an 01E in the rear with an 07K in front; just need to figure out the front output/vdrive!
