Little bit of an update, some progress was made.
Had the car wired up but I didn't really like it so I tore everything out and re wired it again. I think its a lot cleaner and easier to use this way.
And if you don't want to look at it you don't have to
Also found a spot I liked for the ecu and meth controller
Heat exchanger for the intercooler is done as well
Exhaust parts finally came back from being coated. Its starting to look like an engine bay again.
Started to mock up the boost piping
Here is the pipe from the turbo to the intercooler, waiting to be powder coated
All I'm waiting on now is a few sensors and misc. things in the engine bay and she will be ready to start. After that I just need seat brackets and axles and she should be ready for the road. Im sure I will run into a boatload of problems once it gets fired up and that will delay its road worthiness a bit but I'm not too worried.
One small thing that concerns me is my transmission. I had to pull out the shifter linkage assembly because it was stripped where the shaft from the transmission and the shaft from the shifter connect. I fixed the problem and got the linkage back in but now I can't get reverse no matter what I do. I even took the linkage back out and tried to put it in reverse manually by hand but no luck. Spun the engine by hand and tried to get it to pop in but nothing. Since reverse gear isn't synchro'd I am wondering what the problem could be, any tips would be appreciated.
