Hanks URQ 2.6L Autopsy
Hapster
Re: Hanks 81 URQ, 4 headgaskets later....
Post by Hapster »
ShavedQuattro wrote:Sam, it is livable that is for sure, but not the same as a balanced bottom end. Like I said in the other thread, with a balanced bottom end, cruising around at 4500 is natural and clean. It is kind of like driving around a sport bike, where "put put" at 6000rpm is not a big deal. Now I notice it. I am sure my fuel economy has gone up as I am aware of the extra vibration. There are two sets of resonants from my butt butt dyno, without any math or real live data. It feels like there is a bit of a vibration at 3600, and another at around 6800. I am still reving to 8500, and it still makes a silly amount of power at that level. I am using an adjustable cam gear now, and 4 degree's of retard flows a stupid amount more of air. Javad back in the day picked up 63whp by retarding the cam timing 4 degrees( from ~485whp to ~543). I feel like I did the same thing. Put it this way
Put it this way, if I were to take the engine out again and had the time, I would take it apart to balance it. For the 250$, it is a hell of a mod that makes the car feel so much more refined. Remember how smooth the 20v felt after coming from the 20v? Kindof like that.
On another note, I am using an adjustable cam gear now, and 4 degree's of retard flows a stupid amount more of air. Javad back in the day picked up 63whp by retarding the cam timing 4 degrees( from ~485whp to ~543). I feel like I did the same thing. Put it this way, with the cam timing at tdc, I could run 90% duty cycle on the injectors at 34psi with ~1400cc injectors. With the cam timing retarded 4 degrees, 90%DC occurs at 28psi. A ton more air is getting in and out of the motor with the retard. I recommend the mod to anybody as long as the turbo still has enough in it(reading jimmy??)
Hey Hank
Way to go gettin her back on the road again. Wait a minute, oh nevah mind. Anyway, I've also got the 034 cam adjustable gear and when Tufty and Brendan were playing around with it there was no perceivable difference whether they went advance or retard with it. Tufty attributes this to the high lift and duration of my custom cams. I also plotted my boost against your graph and you've got me beat by 800 rpm. I don't get to 26 lbs until 4800 rpm. I'm also putting out something on the order of 587 ft/lbs at that same rpm. Can you say, " Freight Train!". Well, congratulations once again. BTW, I'm taking the Monster out today to see if I can find some poor fella in a Super Car.
Hap, with some kind of game near Everboost, Maguire
Peter, I am just nippin at your heels
:lol: It's funny
So you like the adjustable cam huh? I will get one on the way..
Was that boost profile with the cam retarded?
Interesting Hap. Read this thread from Javad's experience... Here is the plot followed by the link with the explaination
http://motorgeek.com/viewtopic.php?f=6& ... start=1650
This is with a 4088r, and cat cams. Those Cat cams had a ton of lift, but yes, cams with lots of durations would probably see less gain.
Here are some pictures of my new little baby and my family of three. He just turned 1 month on Saturday.
:lol: It's funny
Yeah, it is with the cam retarded 4 degrees. In theory, retarding it like that should shift the powerband up in the rpm range. I didn't notice that at all, but the top end is rediculous.
I do like the cam gear, and I sleep better at night knowing that my 200k miles, taken off a half a dozen times with an impact, key way on the cam gear is new, and not possibly fractured. For the 100-160 dollars new(depending on where you guy them from), it is hard to beat.
Hapster
Re: Hanks 81 URQ, 4 headgaskets later and a baby later....(p
Post by Hapster »
First of all that's a beauuutiful family you've got there. Second of all, I can't explain it other than these are some special cams.
Here's my crew. From the left is our youngest daughter, my wife of 43 years, #1 grandson, my 87 year old mom, #3 gs, #2 gs, son-in-law, oldest daughter and yours truly.
ralleyquattro
Post by ralleyquattro »
Congrats on a healthy baby! Before you know it they will be holding a screwdriver and trying to help you adjust everything in site ;)
http://www.motorgeek.com/v/ralleyquattr ... 8af282171e
Cheers
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
pkw
Post by pkw »
that boost graph is with the cams retarded? nice response for a turbo that flows well. a little rs2 would not have much on you for response and you would leave that little bugger in your wake very soon after. now that i see my combo is not too horrible off of boost i am shopping around for a larger turbo myself. re: cams I always figured that it would work well to play it safe and up the lift and duration a mild amount and then do some mods to be able to dial in the overlap. For me 7acams will probably be best because my tractor bottom end is not going to feel too warm and fuzzy above 7k. BTW nice family pics you guys.
mr_aj_johnson wrote:
Mcstiff wrote:
mr_aj_johnson wrote:Congrats on the baby. Try having two of them 10mos one week apart... See what that does to your shop time.
I had two in the same minute :hide:
I almost feel bad for you, however you only had to deal with nine continuous months of pregnant wife. Boys/Girls?
I can only imagine the hell of having a infant and a pregnant wife.
Mine are ~3 and ~8 months, all girls... since we are cluttering up this page...
AFA tech, my cam chain is a bit loose; am I making more power or just retarded?
One last piece of information for the record... Narrow 01e's are maybe not as strong on the 1st gear as i had hoped. Granted, I am dropping the clutch and doing plenty of hard launches on the poor gear, but if my 2600 pound car can't put up with it, chances are that a heavier car would do even worse. The transmission has about 2k miles on it, and started out quiet in 1st. It is pretty whiny in first gear, and it gets worse with every launch. All the other cars are good though!! :)
Quattro Krant
Post by Quattro Krant »
Your wife is a hottie! Congrats on the healthy baby boy.
200 Avant
Post by 200 Avant »
Hank.. what a great pit crew your wife has on her hands. Love the pics..
Lets see if our kids can make a ski/car weekend and turn a few wrenches in the next couple of years
Here's my help..
Attachment ( 24909 ) : Isabella & Dad (800x600).jpg
PRA4WX
Post by PRA4WX »
Mcstiff wrote:
200 Avant wrote:
Hank.. [/quote]
Tele?[/quote]
You know what they say about a man with free heels don't you?! Aah but i joke! :wink: :P
Highlander
Post by Highlander »
Hank Congratulations to you and your wife on the arrival of your baby.
It's a life changing event for sure.
I can't believe the amount of dedication and passion you have for your urq.......it reminds me of myself.
Thanks for sharing all your information, I'm sure it will help others, I know it helps me for sure.
Great work.
Craig
200 Avant
Post by 200 Avant »
Tele... but of course.. I must confess I do dip my knee slightly, dash through the trees like a fairy and skim the bumps.. :D
And.. I'll NEVER put Alipine boot on my feet ever again in my life ... :o
In my book I don't care what you ride or ski on so long as the crew consists of wagging tales, acting like 13 year olds and enjoying coughing on powder..
If anyone is up for a local's day in CO I'm game..
I'm also planning on an Alta weekend in Feb too..
My choices are: M.J., Jones Pass, Berthoud or Steamboat...
Up for a day?
200 Avant wrote:[/quote]
Up for a day?[/quote]
I'd say yes but I've not been for over a season. I'm going to sneak up to Eldora one of these week days. I started Alpine ~84 then boarding (first lesson at Breck before snowboard boots were a thing lol the rentals were Sorels) then Tele in like '04 or 05.
I think this thread needs a vid or Dyno chart to get back on track.
200 Avant
Post by 200 Avant »
sorry for getting off track.. my apologies
[quote="200 Avant"]
quote]
Yum. That is the truth.
You've got yourself a beautiful family there Hank!
PRA4WX
Post by PRA4WX »
Very beautiful family! (cept for your ugly mug! ;-)
mr_aj_johnson
Post by mr_aj_johnson »
IIRC didnt javad start launching in second gear anyway? Skip first!
Re: Hanks 81 URQ to the dyno
Long story short, a early morning fuel pump exchange allowed me to step on the dyno today, but there were other fueling problems I need to sort out. It was a good baseline. I need to take out a bunch of fuel in order to make more power at the current 30psi, and to allow me to have extra fuel to bump up to ~35psi with these injectors.
518whp/460wtq... Pretty happy, considering the tune. I only had 3 pulls due to scheduling, and I talked them into a 4th. I was adding timing, and taking away fuel each run and making 20whp each time. I think I left about 70whp on the table. That is a shame because it would have been the record on this dyno for an awd car. b7 Rs4's made 299.5whp and 279whp for comparison with one stock and the other with bolt on stuffs.
I dont know why they did not include rpm anywhere, but to save on duty cycle up top, I limited our fun to 7700. Looks like it would keep making power to 8500 though!!
Belgarion115
Re: Hanks 81 URQ Dyno'd
Post by Belgarion115 »
WOW! I think this thread needs videos. :)
fasterthenrs2
Post by fasterthenrs2 »
nice Hank
