So its been a few months since my last update, figure its time, as some questions are arising, too.
Motor is in and wired, Griffin radiator (different than the one everyone else uses - dual-pass with inlet and outlet on the same side and no filler neck - although more expensive, makes life 10x easier) with twin 11-inch Maradyne fans wired to an AutoCool PWM fan controller and an RX-7 oil cooler plumbed in just below.
CQ fenders are bolted on in anticipation of fitting an S2 bumper if I ever hear from Frosty Flax again
B4 hood and headlights are bolted up. Still waiting on black carpet and door panels to arrive from New Hampshire, but I the meantime I've re-foamed the air box flaps and installed a new heater core and tested the blower motor. Still working on the instrument cluster, though I have the euro parking light feature enabled/wired up with the correct switch and an aftermarket alarm/keyless entry ready to go. Scored a sweet Becker Traffic Pro for free from a friend and replaced all the switches in the dash with those from a pre-facelift A8. Esoteric, I know, but its the little things, ya know?
Earlier this week I finally got around to having my V8q hubs machined and pressed into B4 front knuckles and B5 hubs pressed into CQ rear knuckles, and I finally got all that stuff swapped out. Front end is all B4q stuff - axles, struts, knuckles, control arms, sway bar while the rear end is all CQ (upgraded from one-piece strut housings).
Yesterday at the junkyard I found a rear subframe with sway bar mounting provisions in the only B3 in the junkyards for miles around, so naturally that found its way home with me... but I won't be installing that until I do solid subframe mounts and control arm bushings (and find a 4k front sway bar to use) later on down the road.
This morning I bolted all the new suspension and axle shafts in, then I set about monkeying with brakes. The rears were easy - TT 225 calipers and carriers over B5 S4 rotors, wham bam thank you ma'am. The fronts, however, are going to be a little more tricky. The late A8 front rotors seemed to be the best fit and would allow use of stock carriers if they weren't, you know, so damn big. With the B5/B6 rotors the B4 G60 and B5 54mm carriers need to be machined a little to fit, and even though he's a nice guy, I don't feel like shelling out another minimum shop charge for 10 minutes of my machinist's time. Tomorrow or Monday I'm going to see about using some TT 225 carriers and possibly the rotors they are currently hugging, though I'm presuming the offset is too shallow on those rotors (not to mention I would also have to re-drill them for 5x112). I wish I hadn't given my stock B5 S4 front rotors away to the guy who bought my HP2s!
And finally, I scored a nearly mint set of B7 cabriolet 17" rims on 235 Contitechs complete with center caps for a steal. I can't wait to bolt them up and see how bad ass they look on the 80!
