Feckin impressive........that's all
Ed's 1992 UrS4 "da fridge" - da movie
highlander69
Re: Ed's 1992 UrS4 "da fridge": dyno tuning
Ed,
Thx for the info Martin! Justin is the only one I've seen melt one of these and that was on a 20vt, so that makes senseralleyquattro wrote:The AAN one is wider and more substantial. But the distance between the engine and mount is identical.
Also, 20vt motors are not that bad, turbo is much higher along with the exhaust etc.
20vt with stock manifold place the exhaust very low and close to both mount, starter and even the oil filter housing.
Ur-q even came with a funky shield for the starter and motor mount as well as the oil filter housing, to protect them from all that heat.
Cheers
Martin
Yes, the motor was balanced by Dave Jones during the rebuild.da_trem wrote:ED, with all the power and revs you got, is your motor balanced?..its not mentioned in your specs.
Thanks Craig!!highlander69 wrote:Ed,
Updated to 1.2.9 and got on the dyno again last night... hit fuel cut immediately. I need to sit down and figure out the new boost controller because even when set to use RPM vs DC for the reference lookup, it is overboosting like crazy. Nevermind trying the new boost target based reference lookup (WTF is the Y axis??). Had to take my n75 DC down to 8% to get it under control. It seems like it may be referencing the closed loop boost targets despite the fact that the PID controller is OFF (all set to 0)???
Anyways, it did 560whp/501wtq on the first clean pull that we got, and that was at about .75 lambda. Tried to make some tweaks then BAM.
FAIL
Aaron providing the obligatory finger for me
Duct tape and zip ties to the rescue so I could have SOME boost on the ride home
Time for a wiggens clamp on the compressor outlet and solid piping.
FAIL
Re: Ed's 1992 UrS4 "da fridge": silicone FAIL
Did the :::WARNING: DANGER TO MANIFOLD::::: light come on and you just ignored it?
Damn kid... That's some powah!!! That over boosting probably accelerated the process though...
The mods never end at this stage... Sigh
- themagellan
hahahahah, busting intake welds every damn time.Hank wrote:Did the :::WARNING: DANGER TO MANIFOLD::::: light come on and you just ignored it?
Re: Ed's 1992 UrS4
Well, fuel cut was set at 340kpa so it didn't exceed that. A 4-ply silicone hose should be able to hold that no problem, it was just a crappy/defective hose I guess. OBX-R brand (it was the 'R' version!!mushasho wrote:Damn kid... That's some powah!!! That over boosting probably accelerated the process though...
I'm gonna get a vanjen clamp for that spot, only $100 for the clamp, yayyy
Hmm, so when are you going to start making some real power?
on my stinking phone!
As if baseline 560whp isn't real power
Lol nicely done!
Nice Ed.
That is why I have sworn off silicone and just went to Vanjens, Hargetts (NLA I guess :/) or Wiggens.
Bought a 2.5" vanjen for the compressor outlet. The Hargetts are just as expensive if not more so for the 3-piece clamps. What makes you think they're NLA?
Nice numbers Ed. You still running the SB SSX/JB combo? How's it holding up to this torture?
Rob
Yessir, full face "stage 4" (old SB nomenclature) w/ JBR FW. Has not slipped once!
Installed a Vanjen clamp on the compressor outlet and hard pipe to get rid of the silicone, boost is BACK.
These clamps are freaking awesome. Uber high quality components, the flanges have a nice machined lip that mates to the pipe for welding. And I can't believe how much movement they allow...crazy.
naked turbo
naked turbo
Re: Ed's 1992 UrS4 "da fridge": boost is BACK
purdy... very purdy. can't wait to get a ride in da fridge at SFEST.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
1995 UrS6 - Black/Ecru ~225,000mi
Rebuilt Engine - installed @ 223,379mi
AAN Build Photos http://goo.gl/a8YHd
Car Photo Stream http://goo.gl/czdLg
Damn I should have gotten one of those instead of vband for my hx40....ugh
drooooll
Yo Ed.. heard you had a tune switching switch with a key lockout... what did you end up with? Thinking it is a good idea for various reasons and was curious... seems like I might be heading down the E85 slope.
urs6ville wrote:Yo Ed.. heard you had a tune switching switch with a key lockout... what did you end up with? Thinking it is a good idea for various reasons and was curious... seems like I might be heading down the E85 slope.
I can order one in for you Dan. let me know when you're ready.
Cool... do you have a reference link though... I wanted to see exactly what it was/mounting possibilities/etcMarc wrote:I can order one in for you Dan. let me know when you're ready.
Here is the one I have:
http://www.amazon.com/gp/aw/d/B001TR5BS ... 00_s00_i00
I mounted it next to the LCD screen under the CC head...will snap a pic tomorrow.
sure. like this:
(you can just order this one if you want, or browse ebay for spst key switch (thats the search term I used):
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
here's a pic dan. I actually haven't even hooked it up yet since I run E85 all the time....but will need to hook it up for the //sfest road trip.
