Ed's 1992 UrS4 "da fridge" - da movie
Re: Ed's 1992 UrS4 "da fridge": dyno tuning
Epic dude. Car sounds and looks amazing. Most importantly how does it FEEL driving?! From ~400whp to 550 is a pretty nice jump... sheesh. From only timing dad's car made another 60whp so I'd say you'll be well into the 600s. Now just be careful with your pistons lol :)
Nice fuel curve, pretty spot on but yeah a tiny bit up top like you said. What were you using for knock - Marc's phones or a sweet copper contraption? We did the latter at Brady's... it looked hilarious but worked awesome. And LOL 33% DC. I was seeing around 70 with the 630cc on only 20psi. Might not last too long with those... haha.
:thumbsup:
roortube
Post by roortube »
Awesome! How's it drive?
Rob
Nice Ed! Is your MAP sensor maxed out? I love how it makes good torque too :) Can't wait to visit and get a ride in this thing again!
Go find some zr1s and post vids :)
Re: Ed's 1992 UrS4
chaloux wrote:Go find some zr1s and post vids :)
THIS ^^^^ OH and we can't forget those pesky lightly modded GTRs!
Ed, you are motivating me to go and do some more tuning! Great numbers!
Thanks all! More to come in a few weeks or so.
chaloux wrote:Epic dude. Car sounds and looks amazing. Most importantly how does it FEEL driving?! From ~400whp to 550 is a pretty nice jump... sheesh. From only timing dad's car made another 60whp so I'd say you'll be well into the 600s. Now just be careful with your pistons lol :)
roortube wrote:Awesome! How's it drive?
Yeah, it is a shit ton of power....so it feels really good :) Driveability is great, easy to drive around town / in traffic (although that is the same as it has been).
I need to continue to adjust fuel and I can also lean the entire curve out a bit more.
I'm not worried about the pistons - lifting the head or slipping the clutch are the main concerns over 600whp... no signs of either so far :thumbsup:
I'm not sure what a "sweet copper contraption" is :idunno: LOL but I had a knock cable plugged into an amplifier w/ some nice noise cancelling headphones. No knock of course, not gonna get it to knock with E85.
loxxrider wrote:Nice Ed! Is your MAP sensor maxed out? I love how it makes good torque too :) Can't wait to visit and get a ride in this thing again!
LOL are you asking why only 32psi? :foff: VEMS map sensor is good to ~44psi so I think I'll be good :)
Man, there are not many fun cars around here to play with...sucks. There was some douche in a puke green e46 m3 that was revving his engine next to me at a light yesterday... it was right before a highway on-ramp that merges 2 lanes to 1. He tried to get the jump and merge in front of my so i opened the dump and ripped it until he was just a spec in my rear view mirror. But that's no fun...need some fast cars to play.
I also need to update my firmware for the new boost control features. I'm still on 1.1.81 :hide:
FRCFD5
Post by FRCFD5 »
What mustang mounts did you get? :) Ill have to upgrade mine as well when i put the new motor in.
I had just asked him that last week... I believe he went with Energy Suspension Part #ENS-4-1104
Correct. They are GM transmission mounts.
Have your grinder ready. There is quite a bit of modification required to make them fit, but once they're in they are nice and solid, but still comfortable.
we are modding a bunch of them right now for plug and play. If you can wait a tad longer, you can have our CNC do the work ;)
Post by vt10vt »
Awesome numbers, can't imagine what that's like behind the wheel! As others have said, car sounds great as well, congrats!
What part of the mounts needed so much modification?
FRCFD5
Post by FRCFD5 »
Hank wrote:we are modding a bunch of them right now for plug and play. If you can wait a tad longer, you can have our CNC do the work ;)
keep me in the loop :) Looks like i should just leave my CC # with you....
Nice work!
vt10vt wrote:Awesome numbers, can't imagine what that's like behind the wheel! As others have said, car sounds great as well, congrats!
Thanks... For a C4, you need to notch the corners of the mounting brackets on the upper plate. You can leave the lower plate untouched. The passenger side needs the actual poly mount modified...need to do some grinding to get it to fit into the rounded bracket that is on the frame rail.
Apparently there is not quite as much modification required on the smaller chassis cars - I think I am the first one to try these on a C4 so it was a bit of an experiment, but it worked out.
PRY4SNO wrote:Nice work!
Thx!
Re: Ed's 1992 UrS4 "da fridge": Fuel system done...
gtn116 wrote:At Carlisle gathered around the car:
"This should make it good for... a couple... hundred more horsepower..."
Image Image
so true hahah - great numbers Ed!
jretal
Post by jretal »
Right, on the small chassis, you just need to elongate (or slot) one of the holes and it pops right in. If you angle it right, you can even get away w/o doing anything, but for ease of install/removal, making the hole bigger is worth the effort.
Also, def make sure to wrap them if they're near heat (as you are, Ed). They don't hold up well at all to the turbo heat!
I planned on shielding the turbo side, but I don't think they are exposed to uber heat on the C4 like they are on the smaller chassis cars. The bracket that bolts to the motor is huge and shields a lot of a heat, and there is good air flow on the bottom of the mount. But I'll shield it just in case.
jretal
Post by jretal »
yeah, the mounts are def a bit closer on the B2 chassis than the C4 chassis:
ish is tight on the 4000 w/o a doubt!
wow... yeah, that is also far more exposed to heat than it is on the C4. Ours is nicely tucked under the bracket that bolts to the block
ralleyquattro
Post by ralleyquattro »
jretal wrote:yeah, the mounts are def a bit closer on the B2 chassis than the C4 chassis:
Actually you will be surprised that the C3/C4 and B2/B3/B4 pass side mount (alloy leg) is interchangeable.
I am using the C3 TDI mount on my B4 (with stock B3 sheet metal mounting points).
I had them side by side and they align perfectly, however they do use different points on the block so the C3/C4 mounts do appear to be larger (wider bolt span).
I have also seen a lot of European guys use the stock AAN pass mount in their S2s.
The driver side mount is completely different and will not interchange.
Hope this helps :)
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
Interesting... maybe the end points are the same, but the mount is definitely more shielded with the C4/AAN mounting leg.
ralleyquattro
EDIGREG wrote:Interesting... maybe the end points are the same, but the mount is definitely more shielded with the C4/AAN mounting leg.
The AAN one is wider and more substantial. But the distance between the engine and mount is identical.
Also, 20vt motors are not that bad, turbo is much higher along with the exhaust etc.
20vt with stock manifold place the exhaust very low and close to both mount, starter and even the oil filter housing.
Ur-q even came with a funky shield for the starter and motor mount as well as the oil filter housing, to protect them from all that heat.
Cheers
Martin
Martin Pajak
91 Coupe Quattro
da_trem
Post by da_trem »
ED,
with all the power and revs you got, is your motor balanced?..its not mentionned in your specs.
95 Audi S6, VEMS, BW S362
00 Volvo S70 T5M
