well that would be a master problem not a slave problem.my2000apb wrote:well we are going to go try and bleed it one last time, the pedal jsut doesnt want to return. even though there seemed to be extremely little air in the line
Tim's '86 BLAZE 4kq EPIC PROGESS!!!!
Toxcheap
hmmmm
ok heading out to grab a master cylinder and ill report back!
Frank the quattro tank wrote:[/quote]
ok as for the k24, its a winter only, beater , uber cheap build, mostly from parts that I and friends have lying around. the t-red car will get the good stuff, while the s4 gets teh real motorsport stuffs.
hmmm as for the flywheel, how much loot are we talking here? purchase, machining, etc?
You might want to spring for the 80 FWD 4-cyl flywheel, as it is a single mass unit, which you could probably find if you posted up in the swap meet. If you PM me, I can tell you of someone who will modify that flywheel for a 240mm clutch, and can also provide the FW. Also, wouldn't a holset be better for power than a K24? Just looking out for you.[/quote]my2000apb wrote:sure what you got for 4kq parts?a_CQ wrote:Tim, can I get some of that too?
i need
b5 a4 1.8t clutch and fw
4 green tops
a k24
most of a 3b dp
034 16v wastespark coil
rs2 trans mount arms
um and maybe some other small stuff
and a shartload of 2" aluminum tubing
what you talkign about willis?audidub wrote:did you fix the brakes?
clutch master needs replacement, brakes work great!
ah ok so the shifter box is out on a floating mount that is an arm off the transToxcheap wrote:Would you get out of his post before I split it LOL
Yes the 4K's shifter is fixed to the chassis, it doesn't take much movement to bind it up during shifts. The 5k's shifter is almost the same except it has a bar connected to the transmission, and the shifter itself floats. So if the transmission moves up, down, front back the shifter moves with it reducing binding on shifts.
ok so now the decision is 5k or b5 s4 linkage, i wanted the s4 gear as it has the extra support/alignment arm
and with all new mounts i shouldnt get much movement at all
plus its jsut a lowly 16v VW motor
hah
Toxcheap
haha thanks for the info, jsut checking the site out now, thanks for the advice
ok now for last questions
5k linkage bolts right on to o1e, no probs?
would using b5 s4 gear, allow me a much better short shifter selection? or would they not work in a small chassis car anyway?
Toxcheap
Well in that pic you can see how the 5k shifter would bolt right in and just need the boot and rods. The b5 S4 uses a different style shifter all together. I have a picture uploaded here some where. I'll try to find it. Generally you use the b5 s4 linkage when you get a b5 01E and the urs4 linkage when you get the urs4 01E
I haven't looked into the machining costs yet. You should really look into an HX-40. That might be as cheap as the K24.[/quote]
interesting on the fw
ill prob just get some cheap b5 a4 unit
as for the k24 vs hx40 ill stay k24 for mani etc, its cheap and easy, i have a car that deserves the good parts
I got mine for $35, but that was practically a stealmy2000apb wrote:hmmm as for the flywheel, how much loot are we talking here? purchase, machining, etc?
audikidS4
hello boys, sorry for the delays, ive been gone on an emergency work / legal trip
you will both get your tracing numbers by the end of the day, i promose
ill send the tracking numbers as soon as you clean up my project thread with your posts
CtotheQ
Sorry I got a little wound up Tim. Looking forward to getting those wheels on Tuesday. Just a bit of constructive criticism and I'm not trying to be a dick but, may be be a little more realistic with when you will be able to ship things. At any rate both of your 4k's are f n sick. I was looking around for either a nice 4k or CQ and the coupe popped up first. I will probably own one before to long though. Thanks again.
Dylan
Dylan
how abotu you jsut delete them, ill drive into work on my day off to get your numbers or ill jsut refund you if its that much easier
yeah, i may have found an aba, so ill be going to check that out soonaudikidS4 wrote:What's new with this project - any updates?
its not an obd1 but im going to scoop up a forged crank and get the oil squirters machined in, seems a lot easier than finding an obd1 bottom end in good shape
haha ok will do, its def good for being seen! hahaaudikidS4 wrote:I'm digging this project Tim...actually like the orange paint. I want your red 4000- let me know when your bored with it and want to sell
ill be sure to let everyone know, only reason id sell it is to make a SQ project with a mint frame / shell
i couldnt do it to this car as its sooo clean and repainted etc
ok so im about to replace the master cylinder for the clutch, and i figured while im in there i should probably to a engine/trans swap!!! so out comes the JT today!!!
16vT is in the works 6/14/2010
it must be done for deep snow rally action this winter!!!!!!!!!!!
i got an obd2 aba complete with trans etc and lots of other parts to sell off for FREEE!! and got it delivered for free!! woot, its not an obd1 with oil squirters and forged crankshaft so im buying a forged stroker crank and will be machining the block for oil squirters.
pics to come!!
pics to come!!
a_CQ
