Tim's '86 BLAZE 4kq EPIC PROGESS!!!!
hells ya!!! it still needs more clear but i had to get it done up quick to move it from one garage to another, and its really hard to drive with newspaper all over teh windowsWOMBAT wrote:hahaha yes safety orange!!
hmmmmmm maybe the General John Stark ahahhaahha
JasonAG wrote:ah.... this must be the car your wanting my parts for. i dig it!
oh hells ya
ShavedQuattro wrote:That picture of the donuts is very sweet. I like the project. Get er done!!!
jahhahaha thanks, we finally stopped the donutage and started to drive away and i was liek daaaaaamn that looks like a Q, time for a pic!!!
oh i have plenty of pics to prove itglibobbo21 wrote:in the pic it looks like you just edited the pic in MS Paint lol
i amy be needing a slave cylinder for the clutch, firewall brace works great but its still unwilling to pop back up after the pedal is depressedglibobbo21 wrote:when u gonna drive it its taken you like 2 weeks to paint it?
so i could drop the trans and pop my old one back in so i dont have to try and swap the old one out while the trans is in the car still.
or like jim needing injectors, i could swap in a 16vT with my 01e and not have to replace it hahahahaha
but i do need an 01e slave and clutch line and shift linkage
audidub
we already bled it a few times, try again before we pull it, and if i do ill put an o1e back in with a 16vTaudidub wrote:my 4k did the same thing when i got it up and running, all i did was bleed the slave and it came into it. might try that, or again if you have its a lot easier then "dropping" the tranny
audidub
audidub wrote:might as well if you pull it out switch it out, not like you don't have a 4k to drive for the summer 8)
yeah so many decisions to make,
hmmm what to run for engine mgt?
how does the o1e work with a manual speedo?
hmmmmm that works for the 016 locker to 016 torsen swap, as that housing came in mech and elec speedo cars, but i believe the 01e only came in elec speedo cars,glibobbo21 wrote:same cup swap i thought?
hmmm what to do about speedo signal??? :?
so it appears, after many bleedings, that my clutch slave is failing,
so do i...
pull the steering rack to get easy access to drill out the pin and swp slave cylinders
or
i have a good slave attached to a used 4k 016 box from my T-red car's swap, so i could swap out the whole gearbox and be done with it,
or
third choice
someone give me a obd2 ABA bottom end, wiring harness and ecu and ill be good to rip this JT the hell outta here and get the 16vT rolling!!!!!!
so do i...
or
or
third choice
the 4kq's slave cyl. is pinned in there, not a bolt, yeah it sucksbimmerboy wrote:Why not just do the slave normally?
drill it out and replace
sounds easy, its not
bimmerboy
will the pin push out the other side?bimmerboy wrote:Yea. I know. You can get a punch through the tie rod hole. It's usually not really that hard.
Toxcheap
well we are going to go try and bleed it one last time, the pedal jsut doesnt want to return. even though there seemed to be extremely little air in the line
